FIX: flaky groups_controller_spec (PR #9438)
Sometimes spec which is testing order groups by user count is failing.
My theory is that cause is the randomness of Postgres when the order value is the same for 2 rows.
In spec, we got three groups moderator_group - 0 users group - 1 user other_group - 1 user
And we are expecting that controller will return them in ascending order [moderator, group, other_group]
Because group and other_group contain the same amount of users, we are dealing with luck
Therefore, I believe that adding one more user to other_group should make that query reliable.
It was not crashing on my local machine, so I am not 100% sure.
GitHub
