FIX: flaky test in reports (#7255)
  • FIX: flaky test in reports
diff --git a/spec/models/report_spec.rb b/spec/models/report_spec.rb
index d9ad101..3fe9898 100644
--- a/spec/models/report_spec.rb
+++ b/spec/models/report_spec.rb
@@ -1076,19 +1076,20 @@ describe Report do
       it "works" do
         expect(report.data.length).to eq(2)
-        expect_row_to_be_equal(report.data[0], khalil, khalil_upload)
-        expect_row_to_be_equal(report.data[1], tarek, tarek_upload)
+        expect_uploads_report_data_to_be_equal(report.data, khalil, khalil_upload)
+        expect_uploads_report_data_to_be_equal(report.data, tarek, tarek_upload)
+    end
-      def expect_row_to_be_equal(row, user, upload)
-        expect(row[:author_id]).to eq(user.id)
-        expect(row[:author_username]).to eq(user.username)
-        expect(row[:author_avatar_template]).to eq(User.avatar_template(user.username, user.uploaded_avatar_id))
-        expect(row[:filesize]).to eq(upload.filesize)
-        expect(row[:extension]).to eq(upload.extension)
-        expect(row[:file_url]).to eq(Discourse.store.cdn_url(upload.url))
-        expect(row[:file_name]).to eq(upload.original_filename.truncate(25))
-      end
+    def expect_uploads_report_data_to_be_equal(data, user, upload)
+      row = data.find { |r| r[:author_id] == user.id }
+      expect(row[:author_id]).to eq(user.id)
+      expect(row[:author_username]).to eq(user.username)
+      expect(row[:author_avatar_template]).to eq(User.avatar_template(user.username, user.uploaded_avatar_id))
+      expect(row[:filesize]).to eq(upload.filesize)
+      expect(row[:extension]).to eq(upload.extension)
+      expect(row[:file_url]).to eq(Discourse.store.cdn_url(upload.url))
+      expect(row[:file_name]).to eq(upload.original_filename.truncate(25))
     include_examples "no data"
@@ -1108,16 +1109,9 @@ describe Report do
       it "works" do
-        expect_row_to_be_equal(report.data[0], john, 1, 0)
-        expect_row_to_be_equal(report.data[1], matt, 1, 0)
-      end
-      def expect_row_to_be_equal(row, user, ignores, mutes)
-        expect(row[:ignored_user_id]).to eq(user.id)
-        expect(row[:ignored_username]).to eq(user.username)
-        expect(row[:ignored_user_avatar_template]).to eq(User.avatar_template(user.username, user.uploaded_avatar_id))
-        expect(row[:ignores_count]).to eq(ignores)
-        expect(row[:mutes_count]).to eq(mutes)
+        expect_ignored_users_report_data_to_be_equal(report.data, john, 1, 0)
+        expect_ignored_users_report_data_to_be_equal(report.data, matt, 1, 0)
       context "when muted users exist" do
@@ -1128,12 +1122,22 @@ describe Report do
         it "works" do
-          expect_row_to_be_equal(report.data[0], john, 1, 1)
-          expect_row_to_be_equal(report.data[1], matt, 1, 1)
+          expect_ignored_users_report_data_to_be_equal(report.data, john, 1, 1)
+          expect_ignored_users_report_data_to_be_equal(report.data, matt, 1, 1)
+    def expect_ignored_users_report_data_to_be_equal(data, user, ignores, mutes)
+      row = data.find { |r| r[:ignored_user_id] == user.id }
+      expect(row).to be_present
+      expect(row[:ignored_user_id]).to eq(user.id)
+      expect(row[:ignored_username]).to eq(user.username)
+      expect(row[:ignored_user_avatar_template]).to eq(User.avatar_template(user.username, user.uploaded_avatar_id))
+      expect(row[:ignores_count]).to eq(ignores)
+      expect(row[:mutes_count]).to eq(mutes)
+    end
GitHub sha: 41563ba6
