Fix frontend tests on Travis (#8089)
  • Remove obsolete travis cache option (apt)
See: https://github.com/travis-ci/travis-ci/issues/5876
  • Travis config value “addons.postresql” is a string
  • Update Travis from trusty to xenial
Fixes the frontend build, which was failing because Chrome has dropped Trusty support in the latest version. See: Travis is downloading older Chrome versions in place of chrome: stable - Travis CI Discussions & Feedback - Travis CI Community
diff --git a/.travis.yml b/.travis.yml
index c134e72..7119b6c 100644
--- a/.travis.yml
+++ b/.travis.yml
@@ -21,7 +21,7 @@ env:
 addons:
   chrome: stable
-  postgresql: 9.6
+  postgresql: "9.6"
   apt:
     update: true
     packages:
@@ -40,10 +40,9 @@ services:
   - redis-server
 sudo: required
-dist: trusty
+dist: xenial
 cache:
-  apt: true
   yarn: true
   directories:
     - vendor/bundle
GitHub sha: eeb84806
