FIX: Generate webhook payloads before destroy events (PR #6325)
GitHub
You’ve signed the CLA, vinothkannans. Thank you! This pull request is ready for review.
@tgxworld can you review?
@vinothkannans I think we should use around_destroy here instead - https://stackoverflow.com/questions/4998553/rails-around-callbacks. The documentation around this is quite poor but it basically allows us to do something like this.
def around_destroy
  payload = generate_webhook_payload
  yield
  queue_webhook(payload)
This can just be WebHook.enqueue_hooks(type, "#{type}_destroyed".to_sym,
Why not just do this?
def email
  primary_email&.email
I think primary_email can’t be nil. But only in the above commented spec url we making it as nil by removing user_emails table. I feel like it’s incorrect. So I need to ask @tgxworld whether it’s possible to keep using primary_email.email by fixing the old spec.
Sure, I will remove those extra lines before merging this :wink:
Have you tried setting up a user webhook and deleting a user? Pretty sure the email records are deleted before the webhook triggers :wink:
Yes, preventing that is the job for this PR.
I think the name here should be enqueue_destroyed_web_hook
Maybe HasDestroyedWebHook? I feel like HasWebHooks is too generic here.
Yea I think we should fix the old spec here.
:+1:
Since Post and Topic are only soft destroyed, perhaps we can only generate the payload after it has been trashed?
After a post is soft deleted by author we changing the raw with (post withdrawn by author... text. I think it’s good to keep it like all other “destroyed” webhooks.
@tgxworld done. I hope it’s mergable now.
LGTM :+1:
