FIX: get vimeo URL from `data-original-href` iframe attribute
FIX: get vimeo URL from data-original-href iframe attribute
diff --git a/lib/pretty_text.rb b/lib/pretty_text.rb
index c32f603..7f06bb6 100644
--- a/lib/pretty_text.rb
+++ b/lib/pretty_text.rb
@@ -375,8 +375,13 @@ module PrettyText
   def self.convert_vimeo_iframes(doc)
     doc.css("iframe[src*='player.vimeo.com']").each do |iframe|
-      vimeo_id = iframe['src'].split('/').last
-      iframe.replace "<p><a href='https://vimeo.com/#{vimeo_id}'>https://vimeo.com/#{vimeo_id}</a></p>"
+      if iframe["data-original-href"].present?
+        vimeo_url = iframe["data-original-href"]
+      else
+        vimeo_id = iframe['src'].split('/').last
+        vimeo_url = "https://vimeo.com/#{vimeo_id}"
+      end
+      iframe.replace "<p><a href='#{vimeo_url}'>#{vimeo_url}</a></p>"
GitHub sha: 66582ed9
I don’t see a security hole here, but we should always be a bit extra safe here.
What if data-original-href is > <script>alert(1)</script> I know the odds of this kind of storm hitting are close to zero cause there is an IFRAME at play, but still we should do the standard url escaping here.
Agreed, done in:
