FIX: GitHub commit onebox should only be used for single commits
Links to multiple commits will now use the default whitelistedgeneric onebox.
Onebox of github commits overview is just the onebox of the first commit - feature - Discourse Meta
diff --git a/lib/onebox/engine/github_commit_onebox.rb b/lib/onebox/engine/github_commit_onebox.rb
index d598fd1..30bbf9f 100644
--- a/lib/onebox/engine/github_commit_onebox.rb
+++ b/lib/onebox/engine/github_commit_onebox.rb
@@ -7,7 +7,7 @@ module Onebox
       include LayoutSupport
       include JSON
-      matches_regexp Regexp.new("^https?://(?:www\.)?(?:(?:\w)+\.)?(github)\.com(?:/)?(?:.)*/commits?/")
+      matches_regexp Regexp.new("^https?://(?:www\.)?(?:(?:\w)+\.)?(github)\.com(?:/)?(?:.)*/commit/")
       always_https
       def url
@@ -19,9 +19,9 @@ module Onebox
       def match
         return @match if @match
-        @match = @url.match(%{github\.com/(?<owner>[^/]+)/(?<repository>[^/]+)/commits?/(?<sha>[^/]+)})
+        @match = @url.match(%{github\.com/(?<owner>[^/]+)/(?<repository>[^/]+)/commit/(?<sha>[^/]+)})
-        @match = @url.match(%{github\.com/(?<owner>[^/]+)/(?<repository>[^/]+)/pull/(?<pr>[^/]+)/commits?/(?<sha>[^/]+)}) if @match.nil?
+        @match = @url.match(%{github\.com/(?<owner>[^/]+)/(?<repository>[^/]+)/pull/(?<pr>[^/]+)/commit/(?<sha>[^/]+)}) if @match.nil?
         @match
diff --git a/spec/lib/onebox/engine/github_commit_onebox_spec.rb b/spec/lib/onebox/engine/github_commit_onebox_spec.rb
index 8d54133..62673ff 100644
--- a/spec/lib/onebox/engine/github_commit_onebox_spec.rb
+++ b/spec/lib/onebox/engine/github_commit_onebox_spec.rb
@@ -58,8 +58,8 @@ describe Onebox::Engine::GithubCommitOnebox do
   describe "PR with commit URL" do
     before(:all) do
-      @link = "https://github.com/discourse/discourse/pull/4662/commits/803d023e2307309f8b776ab3b8b7e38ba91c0919"
-      @uri = "https://api.github.com/repos/discourse/discourse/commits/803d023e2307309f8b776ab3b8b7e38ba91c0919"
+      @link = "https://github.com/discourse/discourse/pull/4662/commit/803d023e2307309f8b776ab3b8b7e38ba91c0919"
+      @uri = "https://api.github.com/repos/discourse/discourse/commit/803d023e2307309f8b776ab3b8b7e38ba91c0919"
     include_context "engines"
GitHub sha: 4103d115
