FIX: Gravatar uploads being dependent on authorized_extensions.
diff --git a/app/models/upload.rb b/app/models/upload.rb
index bd1f079..fcb67ca 100644
--- a/app/models/upload.rb
+++ b/app/models/upload.rb
@@ -29,6 +29,7 @@ class Upload < ActiveRecord::Base
   attr_accessor :for_private_message
   attr_accessor :for_export
   attr_accessor :for_site_setting
+  attr_accessor :for_gravatar
   validates_presence_of :filesize
   validates_presence_of :original_filename
diff --git a/app/models/user_avatar.rb b/app/models/user_avatar.rb
index b5baafd..741f952 100644
--- a/app/models/user_avatar.rb
+++ b/app/models/user_avatar.rb
@@ -43,7 +43,8 @@ class UserAvatar < ActiveRecord::Base
             tempfile,
             "gravatar#{ext}",
             origin: gravatar_url,
-            type: "avatar"
+            type: "avatar",
+            for_gravatar: true
           ).create_for(user_id)
           if gravatar_upload_id != upload.id
diff --git a/lib/file_helper.rb b/lib/file_helper.rb
index 769c02c..443cceb 100644
--- a/lib/file_helper.rb
+++ b/lib/file_helper.rb
@@ -124,6 +124,10 @@ class FileHelper
     (@memoized ||= {})[args] ||= yield
+  def self.supported_gravatar_extensions
+    @@supported_gravatar_images ||= Set.new(%w{jpg jpeg png gif})
+  end
   def self.supported_images
     @@supported_images ||= Set.new %w{jpg jpeg png gif svg ico}
diff --git a/lib/upload_creator.rb b/lib/upload_creator.rb
index ffae64e..e28f33e 100644
--- a/lib/upload_creator.rb
+++ b/lib/upload_creator.rb
@@ -21,6 +21,7 @@ class UploadCreator
   #  - for_private_message (boolean)
   #  - pasted (boolean)
   #  - for_export (boolean)
+  #  - for_gravatar (boolean)
   def initialize(file, filename, opts = {})
     @file = file
     @filename = (filename || "").gsub(/[^[:print:]]/, "")
@@ -116,6 +117,7 @@ class UploadCreator
       @upload.for_theme           = true if @opts[:for_theme]
       @upload.for_export          = true if @opts[:for_export]
       @upload.for_site_setting    = true if @opts[:for_site_setting]
+      @upload.for_gravatar        = true if @opts[:for_gravatar]
       return @upload unless @upload.save
diff --git a/lib/validators/upload_validator.rb b/lib/validators/upload_validator.rb
index 5c785c2..7e2d137 100644
--- a/lib/validators/upload_validator.rb
+++ b/lib/validators/upload_validator.rb
@@ -26,6 +26,13 @@ class Validators::UploadValidator < ActiveModel::Validator
       return true
+    if upload.for_gravatar &&
+       FileHelper.supported_gravatar_extensions.include?(extension)
+      maximum_image_file_size(upload)
+      return true
+    end
     if is_authorized?(upload, extension)
       if FileHelper.is_supported_image?(upload.original_filename)
         authorized_image_extension(upload, extension)
diff --git a/spec/models/user_avatar_spec.rb b/spec/models/user_avatar_spec.rb
index 4d08f72..b4e6a54 100644
--- a/spec/models/user_avatar_spec.rb
+++ b/spec/models/user_avatar_spec.rb
@@ -15,7 +15,7 @@ describe UserAvatar do
       before do
         temp.binmode
         # tiny valid png
-        temp.write(Base64.decode64("R0lGODlhAQABALMAAAAAAIAAAACAAICAAAAAgIAAgACAgMDAwICAgP8AAAD/AP//AAAA//8A/wD//wBiZCH5BAEAAA8ALAAAAAABAAEAAAQC8EUAOw=="))
+        temp.write(Base64.decode64("iVBORw0KGgoAAAANSUhEUgAAAAEAAAABCAYAAAAfFcSJAAAACklEQVR4nGMAAQAABQABDQottAAAAABJRU5ErkJggg=="))
         temp.rewind
         FileHelper.expects(:download).returns(temp)
@@ -28,7 +28,6 @@ describe UserAvatar do
         freeze_time Time.now
         expect { avatar.update_gravatar! }.to change { Upload.count }.by(1)
         expect(avatar.gravatar_upload).to eq(Upload.last)
         expect(avatar.last_gravatar_download_attempt).to eq(Time.now)
         expect(user.reload.uploaded_avatar).to eq(nil)
@@ -36,7 +35,13 @@ describe UserAvatar do
         expect do
           avatar.destroy
         end.to_not change { Upload.count }
+      end
+      it "updates gravatars even if uploads have been disabled" do
+        SiteSetting.authorized_extensions = ""
+        expect { avatar.update_gravatar! }.to change { Upload.count }.by(1)
+        expect(avatar.gravatar_upload).to eq(Upload.last)
       describe 'when user has an existing custom upload' do
GitHub sha: 7bd93eba
