FIX: Handle multiple holidays in the same day (#118)
If a user had two holidays in the same day, the calendar would show only of them, but the username would be shown twice. This ensures the calendar shows both holidays and the username only once.
index 0d8460c..09fb275 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -411,16 +411,21 @@ after_initialize do
         grouped[identifier] ||= {
           type: :grouped,
-          name: event.description,
+          name: [],
           usernames: []
+        grouped[identifier][:name] << event.description
         grouped[identifier][:usernames] << event.username
-    grouped.each { |_, v| v[:usernames].sort! }
+    grouped.each do |_, v|
+      v[:name] = v[:name].sort.join(", ")
+      v[:usernames].sort!
+      v[:usernames].uniq!
+    end
     standalones + grouped.values
diff --git a/spec/serializers/post_serializer_spec.rb b/spec/serializers/post_serializer_spec.rb
index d63bc3c..2339527 100644
--- a/spec/serializers/post_serializer_spec.rb
+++ b/spec/serializers/post_serializer_spec.rb
@@ -27,4 +27,24 @@ describe PostSerializer do
     expect(json[:post][:group_timezones]["admins"].count).to eq(1)
     expect(json[:post][:group_timezones]["trust_level_0"].count).to eq(2)
+  it "groups calendar events correctly" do
+    user = Fabricate(:user)
+    user.upsert_custom_fields(::DiscourseCalendar::REGION_CUSTOM_FIELD => 'ar')
+    post = create_post(raw: "[calendar]\n[/calendar]")
+    SiteSetting.holiday_calendar_topic_id = post.topic.id
+    freeze_time Date.new(2021, 4, 1)
+    ::DiscourseCalendar::CreateHolidayEvents.new.execute({})
+    json = PostSerializer.new(post.reload, scope: Guardian.new).as_json
+    expect(json[:post][:calendar_details].map { |x| x[:name] }).to contain_exactly(
+      "Día del Veterano y de los Caídos en la Guerra de Malvinas, Viernes Santo",
+      "Día de la Revolución de Mayo",
+      "Feriado puente turístico",
+      "Día de la Independencia"
+    expect(json[:post][:calendar_details].map { |x| x[:usernames] }).to all (contain_exactly(user.username))
+  end
GitHub sha: 4d9d30fe
This commit appears in #118 which was approved by eviltrout and ZogStriP. It was merged by udan11.
