FIX: Handle timeout errors when sending push notifications (#13312)
Decreases the timeout from 60 to 5 seconds and counts timeouts as errors. It also refactors existing specs to reduce duplicate code.
diff --git a/app/services/push_notification_pusher.rb b/app/services/push_notification_pusher.rb
index 3e56da4..33872d5 100644
--- a/app/services/push_notification_pusher.rb
+++ b/app/services/push_notification_pusher.rb
@@ -2,6 +2,7 @@
 class PushNotificationPusher
   TOKEN_VALID_FOR_SECONDS ||= 5 * 60
+  CONNECTION_TIMEOUT_SECONDS = 5
   def self.push(user, payload)
     I18n.with_locale(user.effective_locale) do
@@ -76,7 +77,7 @@ class PushNotificationPusher
   MAX_ERRORS ||= 3
   MIN_ERROR_DURATION ||= 86400 # 1 day
-  def self.handle_generic_error(subscription)
+  def self.handle_generic_error(subscription, error, user, endpoint, message)
     subscription.error_count += 1
     subscription.first_error_at ||= Time.zone.now
@@ -86,6 +87,16 @@ class PushNotificationPusher
     else
       subscription.save!
+    Discourse.warn_exception(
+      error,
+      message: "Failed to send push notification",
+      env: {
+        user_id: user.id,
+        endpoint: endpoint,
+        message: message.to_json
   def self.send_notification(user, subscription, message)
@@ -111,7 +122,10 @@ class PushNotificationPusher
           public_key: SiteSetting.vapid_public_key,
           private_key: SiteSetting.vapid_private_key,
           expiration: TOKEN_VALID_FOR_SECONDS
+        open_timeout: CONNECTION_TIMEOUT_SECONDS,
+        read_timeout: CONNECTION_TIMEOUT_SECONDS,
+        ssl_timeout: CONNECTION_TIMEOUT_SECONDS
       if subscription.first_error_at || subscription.error_count != 0
@@ -123,17 +137,10 @@ class PushNotificationPusher
       if e.response.message == "MismatchSenderId"
         subscription.destroy!
       else
-        handle_generic_error(subscription)
-        Discourse.warn_exception(
-          e,
-          message: "Failed to send push notification",
-          env: {
-            user_id: user.id,
-            endpoint: endpoint,
-            message: message.to_json
+        handle_generic_error(subscription, e, user, endpoint, message)
+    rescue Timeout::Error => e
diff --git a/spec/services/push_notification_pusher_spec.rb b/spec/services/push_notification_pusher_spec.rb
index f00d3ab..62ae1cf 100644
--- a/spec/services/push_notification_pusher_spec.rb
+++ b/spec/services/push_notification_pusher_spec.rb
@@ -16,40 +16,11 @@ RSpec.describe PushNotificationPusher do
       .to eq(UrlHelper.absolute(upload.url))
-  it "sends notification in user's locale" do
-    SiteSetting.allow_user_locale = true
-    user = Fabricate(:user, locale: 'pt_BR')
-    data = <<~JSON
-        "endpoint": "endpoint",
-        "keys": {
-          "p256dh": "p256dh",
-          "auth": "auth"
-    JSON
-    PushSubscription.create!(user_id: user.id, data: data)
-    Webpush.expects(:payload_send).with do |*args|
-      args.to_s.include?("system mencionou")
-    end.once
-    PushNotificationPusher.push(user, {
-      topic_title: 'Topic',
-      username: 'system',
-      excerpt: 'description',
-      topic_id: 1,
-      post_url: "https://example.com/t/1/2",
-      notification_type: 1
-  end
+  context "with user" do
+    fab!(:user) { Fabricate(:user) }
-  it "deletes subscriptions which are erroring regularly" do
-    start = freeze_time
-    user = Fabricate(:user)
-    data = <<~JSON
+    def create_subscription
+      data = <<~JSON
         "keys": {
@@ -57,17 +28,11 @@ RSpec.describe PushNotificationPusher do
           "auth": "auth"
-    JSON
-    sub = PushSubscription.create!(user_id: user.id, data: data)
-    response = Struct.new(:body, :inspect, :message).new("test", "test", "failed")
-    error = Webpush::ResponseError.new(response, "localhost")
-    Webpush.expects(:payload_send).raises(error).times(4)
+      JSON
+      PushSubscription.create!(user_id: user.id, data: data)
+    end
-    # 3 failures in more than 24 hours
-    3.times do
+    def execute_push
         username: 'system',
@@ -76,55 +41,77 @@ RSpec.describe PushNotificationPusher do
+    end
-      freeze_time 1.minute.from_now
+    it "sends notification in user's locale" do
+      SiteSetting.allow_user_locale = true
+      user.update!(locale: 'pt_BR')
+      Webpush.expects(:payload_send).with do |*args|
+        args.to_s.include?("system mencionou")
+      end.once
+      create_subscription
+      execute_push
-    sub.reload
-    expect(sub.error_count).to eq(3)
-    expect(sub.first_error_at).to eq_time(start)
+    it "deletes subscriptions which are erroring regularly" do
+      start = freeze_time
-    freeze_time(2.days.from_now)
+      sub = create_subscription
-      topic_id: 1,
+      response = Struct.new(:body, :inspect, :message).new("test", "test", "failed")
+      error = Webpush::ResponseError.new(response, "localhost")
-    expect(PushSubscription.where(id: sub.id).exists?).to eq(false)
-  end
+      Webpush.expects(:payload_send).raises(error).times(4)
+      # 3 failures in more than 24 hours
+      3.times do
+        execute_push
+        freeze_time 1.minute.from_now
+      end
+      sub.reload
+      expect(sub.error_count).to eq(3)
+      expect(sub.first_error_at).to eq_time(start)
+      freeze_time(2.days.from_now)
-  it "deletes invalid subscriptions during send" do
-    user = Fabricate(:walter_white)
+      execute_push
-    missing_endpoint = PushSubscription.create!(user_id: user.id, data:
-      { p256dh: "public ECDH key", keys: { auth: "private ECDH key" } }.to_json)
+      expect(PushSubscription.where(id: sub.id).exists?).to eq(false)
+    end
+    it "deletes invalid subscriptions during send" do
+      missing_endpoint = PushSubscription.create!(user_id: user.id, data:
+        { p256dh: "public ECDH key", keys: { auth: "private ECDH key" } }.to_json)
-    missing_p256dh = PushSubscription.create!(user_id: user.id, data:
-      { endpoint: "endpoint 1", keys: { auth: "private ECDH key" } }.to_json)
+      missing_p256dh = PushSubscription.create!(user_id: user.id, data:
+        { endpoint: "endpoint 1", keys: { auth: "private ECDH key" } }.to_json)
-    missing_auth = PushSubscription.create!(user_id: user.id, data:
-      { endpoint: "endpoint 2", keys: { p256dh: "public ECDH key" } }.to_json)
+      missing_auth = PushSubscription.create!(user_id: user.id, data:
+        { endpoint: "endpoint 2", keys: { p256dh: "public ECDH key" } }.to_json)
-    valid_subscription = PushSubscription.create!(user_id: user.id, data:
-      { endpoint: "endpoint 3", keys: { p256dh: "public ECDH key", auth: "private ECDH key" } }.to_json)
+      valid_subscription = PushSubscription.create!(user_id: user.id, data:
+        { endpoint: "endpoint 3", keys: { p256dh: "public ECDH key", auth: "private ECDH key" } }.to_json)
-    expect(PushSubscription.where(user_id: user.id)).to contain_exactly(missing_endpoint, missing_p256dh, missing_auth, valid_subscription)
-    Webpush.expects(:payload_send).with(has_entries(endpoint: "endpoint 3", p256dh: "public ECDH key", auth: "private ECDH key")).once
+      expect(PushSubscription.where(user_id: user.id)).to contain_exactly(missing_endpoint, missing_p256dh, missing_auth, valid_subscription)
+      Webpush.expects(:payload_send).with(has_entries(endpoint: "endpoint 3", p256dh: "public ECDH key", auth: "private ECDH key")).once
GitHub sha: 7fcfebe7
This commit appears in #13312 which was approved by eviltrout. It was merged by gschlager.
