FIX: Heisentest - Stored uploads don't always start with 1X
FIX: Heisentest - Stored uploads don’t always start with 1X
This is a common pattern we see in tests. The id of the upload is used to create the URL and we assume the id will always be in a certain range which depends on the database.
diff --git a/spec/components/cooked_post_processor_spec.rb b/spec/components/cooked_post_processor_spec.rb
index 5f7801d..cb17f33 100644
--- a/spec/components/cooked_post_processor_spec.rb
+++ b/spec/components/cooked_post_processor_spec.rb
@@ -1019,7 +1019,8 @@ describe CookedPostProcessor do
           extension: "png",
-        upload.update_column(:url, "#{SiteSetting.Upload.absolute_base_url}/#{Discourse.store.get_path_for_upload(upload)}")
+        stored_path = Discourse.store.get_path_for_upload(upload)
+        upload.update_column(:url, "#{SiteSetting.Upload.absolute_base_url}/#{stored_path}")
         the_post = Fabricate(:post, raw: %Q{This post has a local emoji :+1: and an external upload\n\n![smallest.png|10x20](#{upload.short_url})})
@@ -1028,7 +1029,7 @@ describe CookedPostProcessor do
         expect(cpp.html).to match_html <<~HTML
           <p>This post has a local emoji <img src="https://local.cdn.com/images/emoji/twitter/+1.png?v=6" title=":+1:" class="emoji" alt=":+1:"> and an external upload</p>
-          <p><img src="https://s3.cdn.com/original/1X/#{upload_sha1}.png" alt="smallest.png" width="10" height="20"></p>
+          <p><img src="https://s3.cdn.com/#{stored_path}" alt="smallest.png" width="10" height="20"></p>
         HTML
GitHub sha: 45db98dd
This never happens to me as I reset my test database every time I run the specs…
@ZogStriP you never use autospec?
When I develop I do. But every morning and most of the time before I push some code I reset the db and run rspec.
I guess I don’t leave the test db long enough to generate 1000 upload records.
Still, I don’t think tests should be based on certain id values. Or, if they are, those ids should be seeded as such.
I agree 100% with you. I just explained why I never hit that case and thus never got to fix that test.
