FIX: Heisentest
FIX: Heisentest
We use the id of the upload to calculate a depth partition in the filename. This test would fail if your database had a higher seed because the depth it was looking for was hard coded to 1.
The solution was to not save the records (which is faster anyway) and specify the id of the upload to make the hash deterministic.
diff --git a/spec/components/file_store/base_store_spec.rb b/spec/components/file_store/base_store_spec.rb
index 3de0ff2..623b164 100644
--- a/spec/components/file_store/base_store_spec.rb
+++ b/spec/components/file_store/base_store_spec.rb
@@ -21,16 +21,16 @@ RSpec.describe FileStore::BaseStore do
   describe '#get_path_for_optimized_image' do
-    let(:upload) { Fabricate(:upload) }
+    let(:upload) { Fabricate.build(:upload, id: 100) }
     let(:optimized_path) { "optimized/1X/#{upload.sha1}_1_100x200.png" }
     it 'should return the right path' do
-      optimized = Fabricate(:optimized_image, upload: upload, version: 1)
+      optimized = Fabricate.build(:optimized_image, upload: upload, version: 1)
       expect(FileStore::BaseStore.new.get_path_for_optimized_image(optimized)).to eq(optimized_path)
     it 'should return the right path for `nil` version' do
-      optimized = Fabricate(:optimized_image, upload: upload, version: nil)
+      optimized = Fabricate.build(:optimized_image, upload: upload, version: nil)
GitHub sha: bee68bba
FIX: Heisentest
