FIX: Heisentest
FIX: Heisentest
These tests were failing for the same reason as: https://github.com/discourse/discourse/commit/bee68bba2e2a354fd79178c6a08bc90cf419f5cd
Fix was the same.
diff --git a/spec/multisite/s3_store_spec.rb b/spec/multisite/s3_store_spec.rb
index e95de89..f5ac4e5 100644
--- a/spec/multisite/s3_store_spec.rb
+++ b/spec/multisite/s3_store_spec.rb
@@ -5,6 +5,10 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
   let(:uploaded_file) { file_from_fixtures("smallest.png") }
   let(:upload_sha1) { Digest::SHA1.hexdigest(File.read(uploaded_file)) }
+  def build_upload
+    Fabricate.build(:upload, sha1: upload_sha1, id: 1)
+  end
   context 'uploading to s3' do
     before(:each) do
       SiteSetting.s3_upload_bucket = "some-really-cool-bucket"
@@ -20,7 +24,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
       it "returns the correct url for default and second multisite db" do
         test_multisite_connection('default') do
-          upload = Fabricate(:upload, sha1: upload_sha1)
+          upload = build_upload
           expect(store.store_upload(uploaded_file, upload)).to eq(
             "//#{SiteSetting.s3_upload_bucket}.s3.dualstack.us-east-1.amazonaws.com/uploads/default/original/1X/c530c06cf89c410c0355d7852644a73fc3ec8c04.png"
@@ -28,7 +32,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
         test_multisite_connection('second') do
             "//#{SiteSetting.s3_upload_bucket}.s3.dualstack.us-east-1.amazonaws.com/uploads/second/original/1X/c530c06cf89c410c0355d7852644a73fc3ec8c04.png"
@@ -56,7 +60,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
       it "removes the file from s3 on multisite" do
           store.expects(:get_depth_for).with(upload.id).returns(0)
           s3_helper.expects(:s3_bucket).returns(s3_bucket).at_least_once
           upload.update_attributes!(url: "//s3-upload-bucket.s3.dualstack.us-west-1.amazonaws.com/uploads/default/original/1X/#{upload.sha1}.png")
@@ -73,7 +77,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
       it "removes the file from s3 on another multisite db" do
           upload.update_attributes!(url: "//s3-upload-bucket.s3.dualstack.us-west-1.amazonaws.com/uploads/second/original/1X/#{upload.sha1}.png")
@@ -95,7 +99,7 @@ RSpec.describe 'Multisite s3 uploads', type: :multisite do
             upload.update_attributes!(url: "//s3-upload-bucket.s3.dualstack.us-west-1.amazonaws.com/discourse-uploads/uploads/default/original/1X/#{upload.sha1}.png")
GitHub sha: 0f73026c
