Fix heisentest.
Fix heisentest.
diff --git a/spec/integration/cakeday_spec.rb b/spec/integration/cakeday_spec.rb
index bd27295..b6518c9 100644
--- a/spec/integration/cakeday_spec.rb
+++ b/spec/integration/cakeday_spec.rb
@@ -167,9 +167,7 @@ describe "Cakeyday" do
           body = JSON.parse(response.body)
-          expect(body["anniversaries"].map { |u| u["id"] }).to eq(
-            [user.id, user2.id]
+          expect(body["anniversaries"].map { |u| u["id"] }).to contain_exactly(user.id, user2.id)
           get "/cakeday/anniversaries.json", params: {
             page: 0,
@@ -179,9 +177,7 @@ describe "Cakeyday" do
-            [user3.id, user4.id]
+          expect(body["anniversaries"].map { |u| u["id"] }).to contain_exactly(user3.id, user4.id)
GitHub sha: f1438492
