FIX: Hide a post's pending flag count from TL4 users. (#13129)
FIX: Hide a post’s pending flag count from TL4 users. (#13129)
They can’t see the review queue, so there’s no reason to show a button with the post’s pending flag count in the post controls.
diff --git a/lib/guardian/topic_guardian.rb b/lib/guardian/topic_guardian.rb
index 8539138..98e5145 100644
--- a/lib/guardian/topic_guardian.rb
+++ b/lib/guardian/topic_guardian.rb
@@ -17,9 +17,15 @@ module TopicGuardian
     return false if anonymous? || topic.nil?
     return true if is_staff?
+    is_category_group_moderator?(topic.category)
+  end
+  def can_moderate_topic?(topic)
+    return false if anonymous? || topic.nil?
+    return true if is_staff?
     can_perform_action_available_to_group_moderators?(topic)
-  alias :can_moderate_topic? :can_review_topic?
   def can_create_shared_draft?
     SiteSetting.shared_drafts_enabled? && can_see_shared_draft?
diff --git a/spec/components/guardian/topic_guardian_spec.rb b/spec/components/guardian/topic_guardian_spec.rb
index c42d44a..d7010a9 100644
--- a/spec/components/guardian/topic_guardian_spec.rb
+++ b/spec/components/guardian/topic_guardian_spec.rb
@@ -112,4 +112,13 @@ describe TopicGuardian do
+  describe '#can_review_topic?' do
+    it 'returns false for TL4 users' do
+      tl4_user = Fabricate(:user, trust_level: TrustLevel[4])
+      topic = Fabricate(:topic)
+      expect(Guardian.new(tl4_user).can_review_topic?(topic)).to eq(false)
+    end
+  end
GitHub sha: a5fddd5c
This commit appears in #13129 which was approved by eviltrout and SamSaffron. It was merged by SamSaffron.
