FIX: if mandatory parent tag is missing, add it
Previous behaviour was to silently remove tags that belonged to a group with a parent tag that was missing.
The “required parent tag” feature is meant to guide people to use the correct tags and show scoped results in the tag input field, and to help create topic lists of related tags. It isn’t meant to be a strict requirement in the composer that should trigger errors or restrictions.
diff --git a/lib/discourse_tagging.rb b/lib/discourse_tagging.rb
index 1b26986..ffd8b14 100644
--- a/lib/discourse_tagging.rb
+++ b/lib/discourse_tagging.rb
@@ -4,6 +4,13 @@ module DiscourseTagging
   TAGS_FILTER_REGEXP = /[\/\?#\[\]@!\$&'\(\)\*\+,;=\.%\\`^\s|\{\}"<>]+/ # /?#[]@!$&'()*+,;=.%\`^|{}"<>
   TAGS_STAFF_CACHE_KEY = "staff_tag_names"
+  TAG_GROUP_TAG_IDS_SQL = <<-SQL
+      SELECT tag_id
+        FROM tag_group_memberships tgm
+  INNER JOIN tag_groups tg
+          ON tgm.tag_group_id = tg.id
+  SQL
   def self.tag_topic_by_names(topic, guardian, tag_names_arg, append: false)
     if guardian.can_tag?(topic)
       tag_names = DiscourseTagging.tags_for_saving(tag_names_arg, guardian) || []
@@ -55,6 +62,19 @@ module DiscourseTagging
+        # add missing mandatory parent tags
+        parent_tags = TagGroup.includes(:parent_tag).where("tag_groups.id IN (
+          SELECT tg.id
+            FROM tag_groups tg
+      INNER JOIN tag_group_memberships tgm
+           WHERE tg.parent_tag_id IS NOT NULL
+             AND tgm.tag_id IN (?))", tags.map(&:id)).map(&:parent_tag)
+        parent_tags.reject { |t| tag_names.include?(t.name) }.each do |tag|
+          tags << tag
+        end
         # validate minimum required tags for a category
         if !guardian.is_staff? && category && category.minimum_required_tags > 0 && tags.length < category.minimum_required_tags
           topic.errors[:base] << I18n.t("tags.minimum_required_tags", count: category.minimum_required_tags)
@@ -147,28 +167,19 @@ module DiscourseTagging
         all_staff_tags = DiscourseTagging.staff_tag_names
         query = query.where('tags.name NOT IN (?)', all_staff_tags) if all_staff_tags.present?
+    end
+    if opts[:for_input]
       # exclude tag groups that have a parent tag which is missing from selected_tags
-      select_sql = <<-SQL
-      SELECT tag_id
-            FROM tag_group_memberships tgm
-      INNER JOIN tag_groups tg
-              ON tgm.tag_group_id = tg.id
-      SQL
       if selected_tag_ids.empty?
-        sql = "tags.id NOT IN (#{select_sql} WHERE tg.parent_tag_id IS NOT NULL)"
+        sql = "tags.id NOT IN (#{TAG_GROUP_TAG_IDS_SQL} WHERE tg.parent_tag_id IS NOT NULL)"
         query = query.where(sql)
       else
-        # One tag per group restriction
-        exclude_group_ids = TagGroup.where(one_per_topic: true)
-          .joins(:tag_group_memberships)
-          .where('tag_group_memberships.tag_id in (?)', selected_tag_ids)
-          .pluck(:id)
+        exclude_group_ids = one_per_topic_group_ids(selected_tag_ids)
         if exclude_group_ids.empty?
-          sql = "tags.id NOT IN (#{select_sql} WHERE tg.parent_tag_id NOT IN (?))"
+          sql = "tags.id NOT IN (#{TAG_GROUP_TAG_IDS_SQL} WHERE tg.parent_tag_id NOT IN (?))"
           query = query.where(sql, selected_tag_ids)
         else
           # It's possible that the selected tags violate some one-tag-per-group restrictions,
@@ -177,10 +188,22 @@ module DiscourseTagging
             .where(tag_id: selected_tag_ids)
             .where(tag_group_id: exclude_group_ids)
             .map(&:tag_id)
-          sql = "(tags.id NOT IN (#{select_sql} WHERE (tg.parent_tag_id NOT IN (?) OR tg.id in (?))) OR tags.id IN (?))"
+          sql = "(tags.id NOT IN (#{TAG_GROUP_TAG_IDS_SQL} WHERE (tg.parent_tag_id NOT IN (?) OR tg.id in (?))) OR tags.id IN (?))"
           query = query.where(sql, selected_tag_ids, exclude_group_ids, limit_tag_ids)
+    elsif opts[:for_topic] && !selected_tag_ids.empty?
+      # One tag per group restriction
+      unless exclude_group_ids.empty?
+        limit_tag_ids = TagGroupMembership.select('distinct on (tag_group_id) tag_id')
+          .where(tag_id: selected_tag_ids)
+          .where(tag_group_id: exclude_group_ids)
+          .map(&:tag_id)
+        sql = "(tags.id NOT IN (#{TAG_GROUP_TAG_IDS_SQL} WHERE (tg.id in (?))) OR tags.id IN (?))"
+        query = query.where(sql, exclude_group_ids, limit_tag_ids)
+      end
     if guardian.nil? || guardian.is_staff?
@@ -190,6 +213,13 @@ module DiscourseTagging
+  def self.one_per_topic_group_ids(selected_tag_ids)
+    TagGroup.where(one_per_topic: true)
+      .joins(:tag_group_memberships)
+      .where('tag_group_memberships.tag_id in (?)', selected_tag_ids)
+      .pluck(:id)
+  end
   def self.filter_visible(query, guardian = nil)
     guardian&.is_staff? ? query : query.where("tags.id NOT IN (#{hidden_tags_query.select(:id).to_sql})")
diff --git a/spec/components/discourse_tagging_spec.rb b/spec/components/discourse_tagging_spec.rb
index c9ee958..52b52fd 100644
--- a/spec/components/discourse_tagging_spec.rb
+++ b/spec/components/discourse_tagging_spec.rb
@@ -158,6 +158,39 @@ describe DiscourseTagging do
         expect(topic.reload.tags).to eq([hidden_tag])
+    context 'tag group with parent tag' do
+      let(:topic) { Fabricate(:topic, user: user) }
+      let(:post) { Fabricate(:post, user: user, topic: topic, post_number: 1) }
+      before do
+        tag_group = Fabricate(:tag_group, parent_tag_id: tag1.id)
+        tag_group.tags = [tag3]
+      end
+      it "can tag with parent" do
+        valid = DiscourseTagging.tag_topic_by_names(topic, Guardian.new(user), [tag1.name])
+        expect(valid).to eq(true)
+        expect(topic.reload.tags.map(&:name)).to eq([tag1.name])
+      end
+      it "can tag with parent and a tag" do
+        valid = DiscourseTagging.tag_topic_by_names(topic, Guardian.new(user), [tag1.name, tag3.name])
+        expect(topic.reload.tags.map(&:name)).to contain_exactly(*[tag1, tag3].map(&:name))
+      end
+      it "adds all parent tags that are missing" do
+        parent_tag = Fabricate(:tag, name: 'parent')
+        tag_group2 = Fabricate(:tag_group, parent_tag_id: parent_tag.id)
+        tag_group2.tags = [tag2]
+        valid = DiscourseTagging.tag_topic_by_names(topic, Guardian.new(user), [tag3.name, tag2.name])
+          *[tag1, tag2, tag3, parent_tag].map(&:name)
+      end
+    end
   describe '#tags_for_saving' do
diff --git a/spec/integration/category_tag_spec.rb b/spec/integration/category_tag_spec.rb
index 80f7670..e855786 100644
--- a/spec/integration/category_tag_spec.rb
+++ b/spec/integration/category_tag_spec.rb
@@ -196,7 +196,7 @@ describe "category tag restrictions" do
   context "tag groups with parent tag" do
-    it "filter_allowed_tags returns results based on whether parent tag is present or not" do
+    it "for input field, filter_allowed_tags returns results based on whether parent tag is present or not" do
       tag_group.tags = [tag3, tag4]
       expect(filter_allowed_tags(for_input: true)).to contain_exactly(tag1, tag2)
@@ -204,6 +204,14 @@ describe "category tag restrictions" do
       expect(filter_allowed_tags(for_input: true, selected_tags: [tag1.name, tag3.name])).to contain_exactly(tag2, tag4)
+    it "for tagging a topic, filter_allowed_tags allows tags without parent tag" do
+      tag_group.tags = [tag3, tag4]
+      expect(filter_allowed_tags(for_topic: true)).to contain_exactly(tag1, tag2, tag3, tag4)
+      expect(filter_allowed_tags(for_topic: true, selected_tags: [tag1.name])).to contain_exactly(tag1, tag2, tag3, tag4)
+      expect(filter_allowed_tags(for_topic: true, selected_tags: [tag1.name, tag3.name])).to contain_exactly(tag1, tag2, tag3, tag4)
+    end
     context "and category restrictions" do
       let(:car_category)    { Fabricate(:category) }
GitHub sha: c2a8a2bc
