FIX: Ignore `allowlistgeneric` Onebox image sizes (#13240)
FIX: Ignore allowlistgeneric Onebox image sizes (#13240)
  • FIX: Ignore allowlistgeneric Onebox image sizes
The size of an image contained within the preview pane of a Composer window may vary depending on the configuration of the browser displaying the Composer (e.g., dimension of browser window, zoom level, etc.).
Presently, the dimensions of the images from the browser creating the post containing the Onebox will be used to render the Onebox to anyone who views the post. It is safer to let the backend figure out the dimensions of the images. Therefore, exclude .onebox.allowlistedgeneric images from the list of image_sizes sent to the backend.
  • DEV: Replace jQuery selector with pure JS
  • DEV: remove more jQuery
diff --git a/app/assets/javascripts/discourse/app/controllers/composer.js b/app/assets/javascripts/discourse/app/controllers/composer.js
index e0c09b7..f231018 100644
--- a/app/assets/javascripts/discourse/app/controllers/composer.js
+++ b/app/assets/javascripts/discourse/app/controllers/composer.js
@@ -770,14 +770,15 @@ export default Controller.extend({
     // TODO: This should not happen in model
     const imageSizes = {};
-    $("#reply-control .d-editor-preview img").each((i, e) => {
-      const $img = $(e);
-      const src = $img.prop("src");
+    document
+      .querySelectorAll("#reply-control .d-editor-preview img:not(.onebox img)")
+      .forEach((e) => {
+        const src = e.src;
-      if (src && src.length) {
-        imageSizes[src] = { width: $img.width(), height: $img.height() };
+        if (src && src.length) {
+          imageSizes[src] = { width: e.width, height: e.height };
     const promise = composer
       .save({ imageSizes, editReason: this.editReason })
GitHub sha: abac6144
This commit appears in #13240 which was approved by pmusaraj. It was merged by jbrw.
