FIX: Ignore max excerpt length for div excerpts too (#13058)
We support two types of custom excerpts. It can be
or: https://github.com/discourse/discourse/blob/b21f74060e865d809ba466cb52e6cb95c7b0cf1f/lib/excerpt_parser.rb#L120
We also ignore max excerpt length for custom excerpts. But we forgot to process div when ignoring max length.
diff --git a/lib/excerpt_parser.rb b/lib/excerpt_parser.rb
index 27c78bc..d270893 100644
--- a/lib/excerpt_parser.rb
+++ b/lib/excerpt_parser.rb
@@ -4,7 +4,7 @@ class ExcerptParser < Nokogiri::XML::SAX::Document
   attr_reader :excerpt
-  SPAN_REGEX = /<\s*span[^>]*class\s*=\s*['|"]excerpt['|"][^>]*>/
+  CUSTOM_EXCERPT_REGEX = /<\s*(span|div)[^>]*class\s*=\s*['"]excerpt['"][^>]*>/
   def initialize(length, options = nil)
     @length = length
@@ -29,7 +29,7 @@ class ExcerptParser < Nokogiri::XML::SAX::Document
   def self.get_excerpt(html, length, options)
     html ||= ''
-    length = html.length if html.include?('excerpt') && SPAN_REGEX === html
+    length = html.length if html.include?('excerpt') && CUSTOM_EXCERPT_REGEX === html
     me = self.new(length, options)
     parser = Nokogiri::HTML::SAX::Parser.new(me)
     catch(:done) do
diff --git a/spec/components/pretty_text_spec.rb b/spec/components/pretty_text_spec.rb
index f884df7..0436849 100644
--- a/spec/components/pretty_text_spec.rb
+++ b/spec/components/pretty_text_spec.rb
@@ -798,18 +798,24 @@ describe PrettyText do
       expect(post.excerpt).to eq("hello <a href=\"https://site.com\" rel=\"noopener nofollow ugc\">site</a>")
+    it "handles div excerpt at the beginning of a post" do
+      expect(PrettyText.excerpt("<div class='excerpt'>hi</div> test", 100)).to eq('hi')
+    end
     it "handles span excerpt at the beginning of a post" do
       expect(PrettyText.excerpt("<span class='excerpt'>hi</span> test", 100)).to eq('hi')
-      post = Fabricate(:post, raw: "<span class='excerpt'>hi</span> test")
-      expect(post.excerpt).to eq("hi")
+    end
+    it "ignores max excerpt length if a div excerpt is specified" do
+      two_hundred = "123456789 " * 20 + "."
+      text = two_hundred + "<div class='excerpt'>#{two_hundred}</div>" + two_hundred
+      expect(PrettyText.excerpt(text, 100)).to eq(two_hundred)
     it "ignores max excerpt length if a span excerpt is specified" do
       text = two_hundred + "<span class='excerpt'>#{two_hundred}</span>" + two_hundred
-      post = Fabricate(:post, raw: text)
-      expect(post.excerpt).to eq(two_hundred)
     it "unescapes html entities when we want text entities" do
GitHub sha: c62efc0f
This commit appears in #13058 which was approved by CvX. It was merged by AndrewPrigorshnev.
