FIX: Improve anchor links (#12683)
  • FIX: Use theme color for anchor icon
  • FIX: Do not count anchor links
  • FIX: Do not count hashtags links either
  • DEV: Add tests for link_count
  • FIX: Disable anchors in quotes and preview
  • FIX: Try building some anchor slugs for unicode
  • DEV: Fix tests
diff --git a/app/assets/javascripts/discourse/tests/unit/lib/pretty-text-test.js b/app/assets/javascripts/discourse/tests/unit/lib/pretty-text-test.js
index 5d8bd8f..0d42988 100644
--- a/app/assets/javascripts/discourse/tests/unit/lib/pretty-text-test.js
+++ b/app/assets/javascripts/discourse/tests/unit/lib/pretty-text-test.js
@@ -664,7 +664,7 @@ eviltrout</p>
     assert.cooked(
       "># #category-hashtag\n",
-      '<blockquote>\n<h1><a name="category-hashtag" class="anchor" href="#category-hashtag"></a><span class="hashtag">#category-hashtag</span></h1>\n</blockquote>',
+      '<blockquote>\n<h1><span class="hashtag">#category-hashtag</span></h1>\n</blockquote>',
       "it handles category hashtags in simple quotes"
diff --git a/app/assets/javascripts/pretty-text/engines/discourse-markdown/anchor.js b/app/assets/javascripts/pretty-text/engines/discourse-markdown/anchor.js
index 37924d2..03941e6 100644
--- a/app/assets/javascripts/pretty-text/engines/discourse-markdown/anchor.js
+++ b/app/assets/javascripts/pretty-text/engines/discourse-markdown/anchor.js
@@ -1,15 +1,35 @@
+const SPECIAL_CHARACTERS_REGEX = /[\u2000-\u206F\u2E00-\u2E7F\\'!"#$%&()*+,./:;<=>?@[\]^`{|}~’]/g;
 export function setup(helper) {
+  if (helper.getOptions().previewing) {
+    return;
   helper.registerPlugin((md) => {
     md.core.ruler.push("anchor", (state) => {
-      for (let idx = 0; idx < state.tokens.length; idx++) {
-        if (state.tokens[idx].type !== "heading_open") {
+      for (let idx = 0, lvl = 0; idx < state.tokens.length; idx++) {
+        if (
+          state.tokens[idx].type === "blockquote_open" ||
+          (state.tokens[idx].type === "bbcode_open" &&
+            state.tokens[idx].tag === "aside")
+          ++lvl;
+        } else if (
+          state.tokens[idx].type === "blockquote_close" ||
+          (state.tokens[idx].type === "bbcode_close" &&
+          --lvl;
+        if (lvl > 0 || state.tokens[idx].type !== "heading_open") {
           continue;
         const linkOpen = new state.Token("link_open", "a", 1);
         const linkClose = new state.Token("link_close", "a", -1);
-        const slug = state.tokens[idx + 1].content
+        let slug = state.tokens[idx + 1].content
           .toLowerCase()
           .replace(/\s+/g, "-")
           .replace(/[^\w\-]+/g, "")
@@ -17,6 +37,16 @@ export function setup(helper) {
           .replace(/^-+/, "")
           .replace(/-+$/, "");
+        if (slug.length === 0) {
+          slug = state.tokens[idx + 1].content
+            .replace(/\s+/g, "-")
+            .replace(SPECIAL_CHARACTERS_REGEX, "")
+            .replace(/\-\-+/g, "-")
+            .replace(/^-+/, "")
+            .replace(/-+$/, "");
+          slug = encodeURI(slug).replace(/%/g, "").substr(0, 24);
         linkOpen.attrSet("name", slug);
         linkOpen.attrSet("class", "anchor");
         linkOpen.attrSet("href", "#" + slug);
diff --git a/app/assets/stylesheets/common/base/topic-post.scss b/app/assets/stylesheets/common/base/topic-post.scss
index 0bd40e0..110d737 100644
--- a/app/assets/stylesheets/common/base/topic-post.scss
+++ b/app/assets/stylesheets/common/base/topic-post.scss
@@ -99,7 +99,7 @@ $quote-share-maxwidth: 150px;
       a.anchor {
         &:before {
           content: svg-uri(
-            '<svg xmlns="http://www.w3.org/2000/svg" width="16px" height="16px" viewBox="0 0 512 512"><path d="M326.612 185.391c59.747 59.809 58.927 155.698.36 214.59-.11.12-.24.25-.36.37l-67.2 67.2c-59.27 59.27-155.699 59.262-214.96 0-59.27-59.26-59.27-155.7 0-214.96l37.106-37.106c9.84-9.84 26.786-3.3 27.294 10.606.648 17.722 3.826 35.527 9.69 52.721 1.986 5.822.567 12.262-3.783 16.612l-13.087 13.087c-28.026 28.026-28.905 73.66-1.155 101.96 28.024 28.579 74.086 28.749 102.325.51l67.2-67.19c28.191-28.191 28.073-73.757 0-101.83-3.701-3.694-7.429-6.564-10.341-8.569a16.037 16.037 0 0 1-6.947-12.606c-.396-10.567 3.348-21.456 11.698-29.806l21.054-21.055c5.521-5.521 14.182-6.199 20.584-1.731a152.482 152.482 0 0 1 20.522 17.197zM467.547 44.449c-59.261-59.262-155.69-59.27-214.96 0l-67.2 67.2c-.12.12-.25.25-.36.37-58.566 58.892-59.387 154.781.36 214.59a152.454 152.454 0 0 0 20.521 17.196c6.402 4.468 15.064 3.789 20.584-1.731l21.054-21.055c8.35-8.35 12.094-19.239 11.698-29.806a16.037 16.037 0 0 0-6.947-12.606c-2.912-2.005-6.64-4.875-10.341-8.569-28.073-28.073-28.191-73.639 0-101.83l67.2-67.19c28.239-28.239 74.3-28.069 102.325.51 27.75 28.3 26.872 73.934-1.155 101.96l-13.087 13.087c-4.35 4.35-5.769 10.79-3.783 16.612 5.864 17.194 9.042 34.999 9.69 52.721.509 13.906 17.454 20.446 27.294 10.606l37.106-37.106c59.271-59.259 59.271-155.699.001-214.959z"></path></svg>'
+            '<svg xmlns="http://www.w3.org/2000/svg" width="16px" height="16px" viewBox="0 0 512 512" fill="#{$primary-medium}"><path d="M326.612 185.391c59.747 59.809 58.927 155.698.36 214.59-.11.12-.24.25-.36.37l-67.2 67.2c-59.27 59.27-155.699 59.262-214.96 0-59.27-59.26-59.27-155.7 0-214.96l37.106-37.106c9.84-9.84 26.786-3.3 27.294 10.606.648 17.722 3.826 35.527 9.69 52.721 1.986 5.822.567 12.262-3.783 16.612l-13.087 13.087c-28.026 28.026-28.905 73.66-1.155 101.96 28.024 28.579 74.086 28.749 102.325.51l67.2-67.19c28.191-28.191 28.073-73.757 0-101.83-3.701-3.694-7.429-6.564-10.341-8.569a16.037 16.037 0 0 1-6.947-12.606c-.396-10.567 3.348-21.456 11.698-29.806l21.054-21.055c5.521-5.521 14.182-6.199 20.584-1.731a152.482 152.482 0 0 1 20.522 17.197zM467.547 44.449c-59.261-59.262-155.69-59.27-214.96 0l-67.2 67.2c-.12.12-.25.25-.36.37-58.566 58.892-59.387 154.781.36 214.59a152.454 152.454 0 0 0 20.521 17.196c6.402 4.468 15.064 3.789 20.584-1.731l21.054-21.055c8.35-8.35 12.094-19.239 11.698-29.806a16.037 16.037 0 0 0-6.947-12.606c-2.912-2.005-6.64-4.875-10.341-8.569-28.073-28.073-28.191-73.639 0-101.83l67.2-67.19c28.239-28.239 74.3-28.069 102.325.51 27.75 28.3 26.872 73.934-1.155 101.96l-13.087 13.087c-4.35 4.35-5.769 10.79-3.783 16.612 5.864 17.194 9.042 34.999 9.69 52.721.509 13.906 17.454 20.446 27.294 10.606l37.106-37.106c59.271-59.259 59.271-155.699.001-214.959z"></path></svg>'
           float: left;
           margin-left: -20px;
diff --git a/app/models/post_analyzer.rb b/app/models/post_analyzer.rb
index e56d1f7..bd8d58e 100644
--- a/app/models/post_analyzer.rb
+++ b/app/models/post_analyzer.rb
@@ -122,6 +122,10 @@ class PostAnalyzer
     cooked_stripped.css("a").each do |l|
       # Don't include @mentions in the link count
       next if link_is_a_mention?(l)
+      # Don't include heading anchor in the link count
+      next if link_is_an_anchor?(l)
+      # Don't include hashtags in the link count
+      next if link_is_a_hashtag?(l)
       @raw_links << l['href'].to_s
@@ -144,10 +148,17 @@ class PostAnalyzer
   private
   def link_is_a_mention?(l)
-    html_class = l['class']
-    return false if html_class.blank?
     href = l['href'].to_s
-    html_class.to_s['mention'] && href[/^\/u\//] || href[/^\/users\//]
+    l['class'].to_s['mention'] && (href.start_with?("#{Discourse.base_path}/u/") || href.start_with?("#{Discourse.base_path}/users/"))
+  end
+  def link_is_an_anchor?(l)
+    l['class'].to_s['anchor'] && l['href'].to_s.start_with?('#')
+  end
+  def link_is_a_hashtag?(l)
+    href = l['href'].to_s
+    l['class'].to_s['hashtag'] && (href.start_with?("#{Discourse.base_path}/c/") || href.start_with?("#{Discourse.base_path}/tag/"))
diff --git a/app/models/tag.rb b/app/models/tag.rb
index 78b30fb..44c2373 100644
--- a/app/models/tag.rb
+++ b/app/models/tag.rb
@@ -153,6 +153,10 @@ class Tag < ActiveRecord::Base
     SiteSetting.tagging_enabled
+  def url
+    "#{Discourse.base_path}/tag/#{UrlHelper.encode_component(self.name)}"
+  end
   def full_url
     "#{Discourse.base_url}/tag/#{UrlHelper.encode_component(self.name)}"
GitHub sha: e4e2c7c6
This commit appears in #12683 which was approved by pmusaraj. It was merged by nbianca.
