FIX: Improve anchor links (PR #12683)
FIX: Use theme color for anchor icon
FIX: Do not count anchor links
FIX: Do not count hashtags links either
DEV: Add tests for link_count
FIX: Disable anchors in quotes and preview
FIX: Try building some anchor slugs for unicode
GitHub
            '<svg xmlns="http://www.w3.org/2000/svg" width="16px" height="16px" viewBox="0 0 512 512"><path fill="currentColor" d="M326.612 185.391c59.747 59.809 58.927 155.698.36 214.59-.11.12-.24.25-.36.37l-67.2 67.2c-59.27 59.27-155.699 59.262-214.96 0-59.27-59.26-59.27-155.7 0-214.96l37.106-37.106c9.84-9.84 26.786-3.3 27.294 10.606.648 17.722 3.826 35.527 9.69 52.721 1.986 5.822.567 12.262-3.783 16.612l-13.087 13.087c-28.026 28.026-28.905 73.66-1.155 101.96 28.024 28.579 74.086 28.749 102.325.51l67.2-67.19c28.191-28.191 28.073-73.757 0-101.83-3.701-3.694-7.429-6.564-10.341-8.569a16.037 16.037 0 0 1-6.947-12.606c-.396-10.567 3.348-21.456 11.698-29.806l21.054-21.055c5.521-5.521 14.182-6.199 20.584-1.731a152.482 152.482 0 0 1 20.522 17.197zM467.547 44.449c-59.261-59.262-155.69-59.27-214.96 0l-67.2 67.2c-.12.12-.25.25-.36.37-58.566 58.892-59.387 154.781.36 214.59a152.454 152.454 0 0 0 20.521 17.196c6.402 4.468 15.064 3.789 20.584-1.731l21.054-21.055c8.35-8.35 12.094-19.239 11.698-29.806a16.037 16.037 0 0 0-6.947-12.606c-2.912-2.005-6.64-4.875-10.341-8.569-28.073-28.073-28.191-73.639 0-101.83l67.2-67.19c28.239-28.239 74.3-28.069 102.325.51 27.75 28.3 26.872 73.934-1.155 101.96l-13.087 13.087c-4.35 4.35-5.769 10.79-3.783 16.612 5.864 17.194 9.042 34.999 9.69 52.721.509 13.906 17.454 20.446 27.294 10.606l37.106-37.106c59.271-59.259 59.271-155.699.001-214.959z"></path></svg>'
I have not tested this, but I believe it should work. currentColor is a special value that uses the parent element’s styles.
Another thought: how hard would it be to append an icon in the DOM instead of adding it to the pseudo class? If possible, it would be a bit more efficient, since this icon is already loaded in the SVG sprite.
Looks good.
I can’t seem to find it now, but I noticed that the anchor icon was showing up on mobile as well, after tapping or scrolling near a heading. We might want to disable the hover effect on touch/mobile.
I tried using currentColor as you suggested, but it did not work for this case. I think it has something to do with the fact that we use :before.
Adding the icon in DOM is difficult because that would happen in Markdown-It. The alternative is to use decorate cooked, but I find the current solution more simple and better.
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
Ah, right. Tricky… the one remaining problem with $primary-medium is that it won’t work correctly when switching light/dark mode. Can you see whether var(--primary-medium) works here?
