FIX: Improve downsize_uploads (PR #8409)
  • Actually remove original large-sized images
  • Don’t save processed files if their size increased
  • Prevent inconsistent state
GitHub
You’ve signed the CLA, CvX. Thank you! This pull request is ready for review.
You don’t actually need that delta variable :wink:
return if before < upload.filesize
or
return if upload.filesize > before
Are these the only ones where we use an upload_id? What about some of the uploads settings? What about the user profiles?
Ah, yes, that was a leftover from a log-everything version :wink:
Those were taken from Upload’s after_destroy That probably should be updated as well.
Yeah, have a look at this query I think it’s the most up to date.
can you confirm we have indexes on all these tables (especially user avatar / profile)
I would love to see this merged, all the fixes sound great!
@SamSaffron User and UserAvatar have the correct indexes. UserProfile needed an update (https://github.com/discourse/discourse/pull/8691). Category, CustomEmoji, and ThemeField don’t have indexes on those columns - should I add them?
I think we can live with just user and user avatar and user profile for now, people are only going to rarely run this script so it is not a huge deal if it takes a bit longer
