FIX: Improve `Topic.similar_to` with better `Topic#title` matches.
FIX: Improve Topic.similar_to with better Topic#title matches.
This changes PG text search to only match the given title against lexemes that are formed from the title. Likewise, the given raw will only be matched against lexemes that are formed from the post’s raw.
diff --git a/app/models/topic.rb b/app/models/topic.rb
index de3034e..883a35c 100644
--- a/app/models/topic.rb
+++ b/app/models/topic.rb
@@ -581,9 +581,17 @@ class Topic < ActiveRecord::Base
     return [] if title.blank?
     raw = raw.presence || ""
-    search_data = "#{title} #{raw[0...MAX_SIMILAR_BODY_LENGTH]}".strip
-    filter_words = Search.prepare_data(search_data)
-    ts_query = Search.ts_query(term: filter_words, joiner: "|")
+    title_tsquery = Search.set_tsquery_weight_filter(
+      Search.prepare_data(title.strip),
+      'A'
+    raw_tsquery =  Search.set_tsquery_weight_filter(
+      Search.prepare_data(raw[0...MAX_SIMILAR_BODY_LENGTH].strip),
+      'B'
+    tsquery = Search.to_tsquery(term: "#{title_tsquery} & #{raw_tsquery}", joiner: "|")
     candidates = Topic
       .visible
@@ -591,9 +599,9 @@ class Topic < ActiveRecord::Base
       .secured(Guardian.new(user))
       .joins("JOIN topic_search_data s ON topics.id = s.topic_id")
       .joins("LEFT JOIN categories c ON topics.id = c.topic_id")
-      .where("search_data @@ #{ts_query}")
+      .where("search_data @@ #{tsquery}")
       .where("c.topic_id IS NULL")
-      .order("ts_rank(search_data, #{ts_query}) DESC")
+      .order("ts_rank(search_data, #{tsquery}) DESC")
       .limit(SiteSetting.max_similar_results * 3)
     candidate_ids = candidates.pluck(:id)
diff --git a/lib/search.rb b/lib/search.rb
index 02462cd..ade1ee3 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -1025,13 +1025,25 @@ class Search
   def self.ts_query(term: , ts_config:  nil, joiner: nil, weight_filter: nil)
+    to_tsquery(
+      ts_config: ts_config,
+      term: set_tsquery_weight_filter(term, weight_filter),
+      joiner: joiner
+  end
+  def self.to_tsquery(ts_config: nil, term:, joiner: nil)
     ts_config = ActiveRecord::Base.connection.quote(ts_config) if ts_config
-    term = term.gsub("'", "''")
-    tsquery = "TO_TSQUERY(#{ts_config || default_ts_config}, '''#{PG::Connection.escape_string(term)}'':*#{weight_filter}')"
+    tsquery = "TO_TSQUERY(#{ts_config || default_ts_config}, '#{term}')"
     tsquery = "REPLACE(#{tsquery}::text, '&', '#{PG::Connection.escape_string(joiner)}')::tsquery" if joiner
     tsquery
+  def self.set_tsquery_weight_filter(term, weight_filter)
+    term = term.gsub("'", "''")
+    "''#{PG::Connection.escape_string(term)}'':*#{weight_filter}"
+  end
   def ts_query(ts_config = nil, weight_filter: nil)
     @ts_query_cache ||= {}
     @ts_query_cache["#{ts_config || default_ts_config} #{@term} #{weight_filter}"] ||=
diff --git a/spec/models/topic_spec.rb b/spec/models/topic_spec.rb
index b8be9f3..29af224 100644
--- a/spec/models/topic_spec.rb
+++ b/spec/models/topic_spec.rb
@@ -502,37 +502,46 @@ describe Topic do
-  context 'similar_to' do
+  context '.similar_to' do
+    fab!(:category) { Fabricate(:category_with_definition) }
-    it 'returns blank with nil params' do
-      expect(Topic.similar_to(nil, nil)).to be_blank
+    it 'returns an empty array with nil params' do
+      expect(Topic.similar_to(nil, nil)).to eq([])
     context "with a category definition" do
-      let!(:category) { Fabricate(:category_with_definition) }
       it "excludes the category definition topic from similar_to" do
-        expect(Topic.similar_to('category definition for', "no body")).to be_blank
+        expect(Topic.similar_to('category definition for', "no body")).to eq([])
     context 'with a similar topic' do
-      let!(:topic) {
+      fab!(:post) {
         SearchIndexer.enable
-        post = create_post(title: "Evil trout is the dude who posted this topic")
-        post.topic
+        create_post(title: "Evil trout is the dude who posted this topic")
+      let(:topic) { post.topic }
+      before do
+        SearchIndexer.enable
+      end
       it 'returns the similar topic if the title is similar' do
         expect(Topic.similar_to("has evil trout made any topics?", "i am wondering has evil trout made any topics?")).to eq([topic])
-      context "secure categories" do
-        fab!(:category) { Fabricate(:category_with_definition, read_restricted: true) }
+      it 'matches title against title and raw against raw when searching for topics' do
+        topic.update!(title: '1 2 3 numbered titles')
+        post.update!(raw: 'random toy poodle')
+        expect(Topic.similar_to("unrelated term", "1 2 3 poddle")).to eq([])
+      end
+      context "secure categories" do
         before do
-          topic.category = category
-          topic.save
+          category.update!(read_restricted: true)
+          topic.update!(category: category)
         it "doesn't return topics from private categories" do
GitHub sha: 597d542c
