FIX: improves reminders support and adds more specs
diff --git a/jobs/regular/discourse_post_event/send_reminder.rb b/jobs/regular/discourse_post_event/send_reminder.rb
index a54f48d..892f204 100644
--- a/jobs/regular/discourse_post_event/send_reminder.rb
+++ b/jobs/regular/discourse_post_event/send_reminder.rb
@@ -8,20 +8,31 @@ module Jobs
       raise Discourse::InvalidParameters.new(:event_id) if args[:event_id].blank?
       raise Discourse::InvalidParameters.new(:reminder) if args[:reminder].blank?
-      event = Event.includes(post: [:topic], invitees: [:user]).find(args[:event_id])
-      invitees = event.invitees
+      event = DiscoursePostEvent::Event.includes(post: [:topic], invitees: [:user]).find(args[:event_id])
+      invitees = event.invitees.where(status: DiscoursePostEvent::Invitee.statuses[:going])
-      unread_notified_user_ids = Notification.where(
+      already_notified_users = Notification.where(
         read: false,
         notification_type: Notification.types[:custom],
         topic_id: event.post.topic_id,
         post_number: 1
-      ).pluck(:user_id)
-      invitees
-        .where(status: DiscoursePostEvent::Invitee.statuses[:going])
-        .where.not(user_id: unread_notified_user_ids)
-        .find_each do |invitee|
+      event_started = Time.now > event.starts_at
+      # we remove users who have been visiting the topic since event started
+      if event_started
+        invitees = invitees.where.not(
+          user_id: TopicUser
+            .where('topic_users.topic_id = ? AND topic_users.last_visited_at >= ? AND topic_users.last_read_post_number >= ?', event.post.topic_id, event.starts_at, 1)
+            .pluck(:user_id)
+            .concat(already_notified_users.pluck(:user_id))
+      else
+        invitees = invitees.where.not(user_id: already_notified_users.pluck(:user_id))
+      end
+      invitees.find_each do |invitee|
         invitee.user.notifications.create!(
@@ -29,7 +40,7 @@ module Jobs
           data: {
             topic_title: event.post.topic.title,
             display_username: invitee.user.username,
-            message: 'discourse_post_event.notifications.before_event_reminder'
+            message: "discourse_post_event.notifications.#{event_started ? 'after' : 'before'}_event_reminder"
           }.to_json
diff --git a/spec/jobs/regular/discourse_post_event/send_reminder_spec.rb b/spec/jobs/regular/discourse_post_event/send_reminder_spec.rb
new file mode 100644
index 0000000..7d651c3
--- /dev/null
+++ b/spec/jobs/regular/discourse_post_event/send_reminder_spec.rb
@@ -0,0 +1,145 @@
+require 'rails_helper'
+require_relative '../../../fabricators/event_fabricator'
+describe Jobs::DiscoursePostEventSendReminder do
+  let(:admin_1) { Fabricate(:user, admin: true) }
+  let(:topic_1) { Fabricate(:topic, user: admin_1) }
+  let(:going_user) { Fabricate(:user) }
+  let(:visited_going_user) { Fabricate(:user) }
+  let(:not_going_user) { Fabricate(:user) }
+  let(:going_user_unread_notification) { Fabricate(:user) }
+  let(:going_user_read_notification) { Fabricate(:user) }
+  let(:post_1) { Fabricate(:post, topic: topic_1) }
+  let(:reminders) { '-5.minutes' }
+  let(:event_1) { Fabricate(:event, post: post_1, reminders: reminders) }
+  # ensures we start form a known state
+  def init_notifications
+      going_user,
+      not_going_user,
+      going_user_unread_notification,
+      going_user_read_notification,
+      visited_going_user
+    ].each do |user|
+      user.notifications.update_all(read: true)
+    end
+    going_user_unread_notification.notifications.create!(
+      notification_type: Notification.types[:custom],
+      topic_id: post_1.topic_id,
+      post_number: 1,
+      data: {}.to_json
+  end
+  before do
+    freeze_time DateTime.parse('2018-11-10 12:00')
+    Jobs.run_immediately!
+    SiteSetting.calendar_enabled = true
+    SiteSetting.discourse_post_event_enabled = true
+    DiscoursePostEvent::Invitee.create_attendance!(going_user.id, event_1.id, :going)
+    DiscoursePostEvent::Invitee.create_attendance!(not_going_user.id, event_1.id, :not_going)
+    DiscoursePostEvent::Invitee.create_attendance!(going_user_unread_notification.id, event_1.id, :going)
+    DiscoursePostEvent::Invitee.create_attendance!(going_user_read_notification.id, event_1.id, :going)
+    DiscoursePostEvent::Invitee.create_attendance!(visited_going_user.id, event_1.id, :going)
+  end
+  context '#execute' do
+    context 'invalid params' do
+      context 'no invitees given' do
+        it 'raises an invalid parameters errors' do
+          expect {
+            subject.execute(event_id: 1)
+          }.to raise_error(Discourse::InvalidParameters)
+          expect {
+            subject.execute(reminder: 'foo')
+        end
+      end
+    end
+    context 'valid params' do
+      context 'event has not started' do
+        before do
+          event_1.update!(starts_at: Time.now + 1.hour)
+          init_notifications
+        end
+        it 'creates a new notification for going user' do
+          expect(going_user.unread_notifications).to eq(0)
+          expect {
+            subject.execute(event_id: event_1.id, reminder: reminders)
+          }.to change { going_user.reload.unread_notifications }.by(1)
+        end
+        it 'doesn’t create a new notification for not going user' do
+          expect(not_going_user.unread_notifications).to eq(0)
+          expect {
+          }.to change { not_going_user.reload.unread_notifications }.by(0)
+        end
+        it 'doesn’t create a new notification if there’s already one' do
+          expect(going_user_unread_notification.unread_notifications).to eq(1)
+          expect {
+          }.to change { going_user_unread_notification.reload.unread_notifications }.by(0)
+        end
+      end
+      context 'event has started' do
+        before do
+          event_1.update!(starts_at: 4.minutes.ago)
+          TopicUser.change(going_user, event_1.post.topic, last_visited_at: 10.minutes.ago, last_read_post_number: 1)
+          TopicUser.change(visited_going_user, event_1.post.topic, last_visited_at: 2.minutes.ago, last_read_post_number: 1)
+        end
+          expect {
+        end
+          expect {
+        end
+          expect {
+          }.to change {
+            going_user_unread_notification.reload.unread_notifications
+          }.by(0)
+        end
+        it 'doesn’t create a new notification for visiting user' do
+          expect(visited_going_user.unread_notifications).to eq(0)
+          expect {
+          }.to change {
+            visited_going_user.reload.unread_notifications
+          }.by(0)
+        end
+      end
+    end
+  end
+end
GitHub sha: bf67e8b9
from
