FIX: `in:title` search should only search through topic first posts.
FIX: in:title search should only search through topic first posts.
diff --git a/lib/search.rb b/lib/search.rb
index 34893db..0caf6e3 100644
--- a/lib/search.rb
+++ b/lib/search.rb
@@ -847,6 +847,7 @@ class Search
         # C is for tags
         # D is for cooked
         weights = @in_title ? 'A' : (SiteSetting.tagging_enabled ? 'ABCD' : 'ABD')
+        posts = posts.where(post_number: 1) if @in_title
         posts = posts.where("post_search_data.search_data @@ #{ts_query(weight_filter: weights)}")
         exact_terms = @term.scan(Regexp.new(PHRASE_MATCH_REGEXP_PATTERN)).flatten
diff --git a/spec/components/search_spec.rb b/spec/components/search_spec.rb
index 652aa95..bc4239f 100644
--- a/spec/components/search_spec.rb
+++ b/spec/components/search_spec.rb
@@ -1513,19 +1513,14 @@ describe Search do
   context 'in:title' do
     it 'allows for search in title' do
       topic = Fabricate(:topic, title: 'I am testing a title search')
-      _post = Fabricate(:post, topic: topic, raw: 'this is the first post')
+      post2 = Fabricate(:post, topic: topic, raw: 'this is the second post', post_number: 2)
+      post = Fabricate(:post, topic: topic, raw: 'this is the first post', post_number: 1)
       results = Search.execute('title in:title')
-      expect(results.posts.length).to eq(1)
-      results = Search.execute('title t')
+      expect(results.posts.map(&:id)).to eq([post.id])
       results = Search.execute('first in:title')
-      expect(results.posts.length).to eq(0)
-      results = Search.execute('first t')
+      expect(results.posts).to eq([])
     it 'works irrespective of the order' do
GitHub sha: af879111
https://meta.discourse.org/t/search-function-problem/157737/17
