FIX: Include default notification level in category serializer (#9572)
Fixes an issue where the notification level state goes missing when user edits a category in the UI.
diff --git a/app/serializers/category_serializer.rb b/app/serializers/category_serializer.rb
index cb5b2ff..583ee13 100644
--- a/app/serializers/category_serializer.rb
+++ b/app/serializers/category_serializer.rb
@@ -83,8 +83,9 @@ class CategorySerializer < SiteCategorySerializer
   def notification_level
     user = scope && scope.user
-   object.notification_level ||
-     (user && CategoryUser.where(user: user, category: object).first.try(:notification_level))
+    object.notification_level ||
+     (user && CategoryUser.where(user: user, category: object).first.try(:notification_level)) ||
+     CategoryUser.default_notification_level
   def custom_fields
diff --git a/spec/serializers/category_serializer_spec.rb b/spec/serializers/category_serializer_spec.rb
index 1557850..e2a3399 100644
--- a/spec/serializers/category_serializer_spec.rb
+++ b/spec/serializers/category_serializer_spec.rb
@@ -28,4 +28,19 @@ describe CategorySerializer do
     json = described_class.new(category, scope: Guardian.new, root: false).as_json
     expect(json[:custom_fields]).to be_present
+  it "includes the default notification level" do
+    json = described_class.new(category, scope: Guardian.new, root: false).as_json
+    expect(json[:notification_level]).to eq(CategoryUser.default_notification_level)
+  end
+  describe "user notification level" do
+    fab!(:user) { Fabricate(:user) }
+    it "includes the user's notification level" do
+      CategoryUser.set_notification_level_for_category(user, NotificationLevels.all[:watching], category.id)
+      json = described_class.new(category, scope: Guardian.new(user), root: false).as_json
+      expect(json[:notification_level]).to eq(NotificationLevels.all[:watching])
+    end
+  end
GitHub sha: b19dcac2
This commit appears in #9572 which was approved by eviltrout. It was merged by pmusaraj.
