FIX: Inline error when converting html to markdown
Looks like some html elements like aside and section will throw an error when checking if they are inline or not. The commit simply handles
Job exception: undefined method `inline?' for nil:NilClass
and adds a test for it.
diff --git a/lib/html_to_markdown.rb b/lib/html_to_markdown.rb
index 448a0cd..d2fb51f 100644
--- a/lib/html_to_markdown.rb
+++ b/lib/html_to_markdown.rb
@@ -99,7 +99,7 @@ class HtmlToMarkdown
   def is_inline?(node)
-    node.text? || ("br" != node.name && node.description.inline? && node.children.all? { |n| is_inline?(n) })
+    node.text? || ("br" != node.name && node.description&.inline? && node.children.all? { |n| is_inline?(n) })
   def collapse_spaces!(nodes, was_space = true)
diff --git a/spec/components/html_to_markdown_spec.rb b/spec/components/html_to_markdown_spec.rb
index 3d19c66..0fde6ea 100644
--- a/spec/components/html_to_markdown_spec.rb
+++ b/spec/components/html_to_markdown_spec.rb
@@ -65,6 +65,23 @@ describe HtmlToMarkdown do
     expect(html_to_markdown(html)).to eq(markdown.strip)
+  it "doesn't error on non-inline elements like (aside, section)" do
+    html = <<~HTML
+      <aside class="quote no-group">
+      <blockquote>
+      <p>hello.</p>
+      </blockquote>
+      </aside>
+    HTML
+    markdown = <<~MD
+      > hello.
+    MD
+    expect(html_to_markdown(html)).to eq(markdown.strip)
+  end
   it "skips hidden tags" do
     expect(html_to_markdown(%Q{<p>Hello <span style="display: none">cruel </span>World!</p>})).to eq("Hello World!")
     expect(html_to_markdown(%Q{<p>Hello <span hidden>cruel </span>World!</p>})).to eq("Hello World!")
GitHub sha: a89574cc
