FIX: Invalidate database theme cache when hostname changes (#9908)
Hostname can vary per-site on a multisite cluster, so this change requires converting the compiler_version from a constant into a class method which is evaluated at runtime. The value is stored in the theme DistributedCache, so performance impact should be negligible.
diff --git a/app/models/theme.rb b/app/models/theme.rb
index 4f54f9a..da9d357 100644
--- a/app/models/theme.rb
+++ b/app/models/theme.rb
@@ -122,6 +122,19 @@ class Theme < ActiveRecord::Base
     SvgSprite.expire_cache
+  BASE_COMPILER_VERSION = 16
+  def self.compiler_version
+    get_set_cache "compiler_version" do
+      dependencies = [
+        BASE_COMPILER_VERSION,
+        Ember::VERSION,
+        GlobalSetting.cdn_url,
+        Discourse.current_hostname
+      Digest::SHA1.hexdigest(dependencies.join)
+    end
+  end
   def self.get_set_cache(key, &blk)
     if @cache.hash.key? key.to_s
       return @cache[key]
@@ -248,7 +261,7 @@ class Theme < ActiveRecord::Base
     theme_ids = [theme_ids] unless Array === theme_ids
     theme_ids = transform_ids(theme_ids)
-    cache_key = "#{theme_ids.join(",")}:#{target}:#{field}:#{ThemeField::COMPILER_VERSION}"
+    cache_key = "#{theme_ids.join(",")}:#{target}:#{field}:#{Theme.compiler_version}"
     lookup = @cache[cache_key]
     return lookup.html_safe if lookup
@@ -262,7 +275,7 @@ class Theme < ActiveRecord::Base
-    get_set_cache("#{theme_ids.join(",")}:modifier:#{modifier_name}:#{ThemeField::COMPILER_VERSION}") do
+    get_set_cache("#{theme_ids.join(",")}:modifier:#{modifier_name}:#{Theme.compiler_version}") do
       ThemeModifierSet.resolve_modifier_for_themes(theme_ids, modifier_name)
@@ -321,7 +334,7 @@ class Theme < ActiveRecord::Base
   def self.resolve_baked_field(theme_ids, target, name)
     if target == :extra_js
       require_rebake = ThemeField.where(theme_id: theme_ids, target_id: Theme.targets[:extra_js]).
-        where("compiler_version <> ?", ThemeField::COMPILER_VERSION)
+        where("compiler_version <> ?", Theme.compiler_version)
       require_rebake.each { |tf| tf.ensure_baked! }
       require_rebake.map(&:theme_id).uniq.each do |theme_id|
         Theme.find(theme_id).update_javascript_cache!
diff --git a/app/models/theme_field.rb b/app/models/theme_field.rb
index c2e8d06..a15d42e 100644
--- a/app/models/theme_field.rb
+++ b/app/models/theme_field.rb
@@ -60,14 +60,6 @@ class ThemeField < ActiveRecord::Base
   validates :name, format: { with: /\A[a-z_][a-z0-9_-]*\z/i },
                    if: Proc.new { |field| ThemeField.theme_var_type_ids.include?(field.type_id) }
-  BASE_COMPILER_VERSION = 16
-  DEPENDENT_CONSTANTS = [
-    BASE_COMPILER_VERSION,
-    Ember::VERSION,
-    GlobalSetting.cdn_url
-  COMPILER_VERSION = Digest::SHA1.hexdigest(DEPENDENT_CONSTANTS.join)
   belongs_to :theme
   def process_html(html)
@@ -311,18 +303,18 @@ class ThemeField < ActiveRecord::Base
   def ensure_baked!
-    needs_baking = !self.value_baked || compiler_version != COMPILER_VERSION
+    needs_baking = !self.value_baked || compiler_version != Theme.compiler_version
     return unless needs_baking
     if basic_html_field? || translation_field?
       self.value_baked, self.error = translation_field? ? process_translation : process_html(self.value)
       self.error = nil unless self.error.present?
-      self.compiler_version = COMPILER_VERSION
+      self.compiler_version = Theme.compiler_version
       DB.after_commit { CSP::Extension.clear_theme_extensions_cache! }
     elsif extra_js_field?
       self.value_baked, self.error = process_extra_js(self.value)
     elsif basic_scss_field?
       ensure_scss_compiles!
       DB.after_commit { Stylesheet::Manager.clear_theme_cache! }
@@ -332,12 +324,12 @@ class ThemeField < ActiveRecord::Base
       DB.after_commit { SvgSprite.expire_cache }
       self.value_baked = "baked"
     elsif svg_sprite_field?
       self.error = nil
     if self.will_save_change_to_value_baked? ||
@@ -370,7 +362,7 @@ class ThemeField < ActiveRecord::Base
     rescue SassC::SyntaxError => e
       self.error = e.message unless self.destroyed?
     self.value_baked = Digest::SHA1.hexdigest(result.join(",")) # We don't use the compiled CSS here, we just use it to invalidate the stylesheet cache
diff --git a/spec/models/theme_spec.rb b/spec/models/theme_spec.rb
index 04b452c..f32dc33 100644
--- a/spec/models/theme_spec.rb
+++ b/spec/models/theme_spec.rb
@@ -716,7 +716,7 @@ HTML
       first_common_value = Theme.lookup_field(child.id, :desktop, "header")
       first_extra_js_value = Theme.lookup_field(child.id, :extra_js, nil)
-      stub_const(ThemeField, :COMPILER_VERSION, "SOME_NEW_HASH") do
+      Theme.stubs(:compiler_version).returns("SOME_NEW_HASH") do
         second_common_value = Theme.lookup_field(child.id, :desktop, "header")
         second_extra_js_value = Theme.lookup_field(child.id, :extra_js, nil)
@@ -730,5 +730,18 @@ HTML
         expect(new_extra_js_compiler_version).to eq("SOME_NEW_HASH")
+    it 'recompiles when the hostname changes' do
+      theme.set_field(target: :settings, name: :yaml, value: "name: bob")
+      theme_field = theme.set_field(target: :common, name: :after_header, value: '<script>console.log("hello world");</script>')
+      theme.save!
+      expect(Theme.lookup_field(theme.id, :common, :after_header)).to include("_ws=#{Discourse.current_hostname}")
+      SiteSetting.force_hostname = "someotherhostname.com"
+      Theme.clear_cache!
+      expect(Theme.lookup_field(theme.id, :common, :after_header)).to include("_ws=someotherhostname.com")
+    end
GitHub sha: d29d69e1
This commit appears in #9908 which was approved by eviltrout and tgxworld. It was merged by davidtaylorhq.
