FIX: Linting, add tools
diff --git a/assets/javascripts/discourse/initializers/update-state.js.es6 b/assets/javascripts/discourse/initializers/update-state.js.es6
index 8660cad..809a48c 100644
--- a/assets/javascripts/discourse/initializers/update-state.js.es6
+++ b/assets/javascripts/discourse/initializers/update-state.js.es6
@@ -34,7 +34,7 @@ export default {
         Object.keys(JSON.parse(currentUser.encrypt_private)).length === 0)
       withPluginApi("0.8.37", api => {
-        let basePath = getURL('/').replace(/\/$/, '');
+        let basePath = getURL("/").replace(/\/$/, "");
         api.addGlobalNotice(
           I18n.t("encrypt.no_backup_warn", { basePath }),
           "key-backup-notice",
diff --git a/package.json b/package.json
new file mode 100644
index 0000000..9a889c4
--- /dev/null
+++ b/package.json
@@ -0,0 +1,12 @@
+  "name": "discourse-encrypt",
+  "version": "1.0.0",
+  "repository": "git@github.com:discourse/discourse-encrypt.git",
+  "author": "Discourse",
+  "license": "MIT",
+  "devDependencies": {
+    "babel-eslint": "^8.2",
+    "eslint": "^4.19",
+    "prettier": "1.14.3"
diff --git a/yarn.lock b/yarn.lock
index 0000000..1592f34
--- /dev/null
+++ b/yarn.lock
@@ -0,0 +1,1018 @@
+# THIS IS AN AUTOGENERATED FILE. DO NOT EDIT THIS FILE DIRECTLY.
+# yarn lockfile v1
+"@babel/code-frame@7.0.0-beta.44":
+  version "7.0.0-beta.44"
+  resolved "https://registry.yarnpkg.com/@babel/code-frame/-/code-frame-7.0.0-beta.44.tgz#2a02643368de80916162be70865c97774f3adbd9"
+  integrity sha512-cuAuTTIQ9RqcFRJ/Y8PvTh+paepNcaGxwQwjIDRWPXmzzyAeCO4KqS9ikMvq0MCbRk6GlYKwfzStrcP3/jSL8g==
+  dependencies:
+    "@babel/highlight" "7.0.0-beta.44"
+"@babel/generator@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/generator/-/generator-7.0.0-beta.44.tgz#c7e67b9b5284afcf69b309b50d7d37f3e5033d42"
+  integrity sha512-5xVb7hlhjGcdkKpMXgicAVgx8syK5VJz193k0i/0sLP6DzE6lRrU1K3B/rFefgdo9LPGMAOOOAWW4jycj07ShQ==
+  dependencies:
+    "@babel/types" "7.0.0-beta.44"
+    jsesc "^2.5.1"
+    lodash "^4.2.0"
+    source-map "^0.5.0"
+    trim-right "^1.0.1"
+"@babel/helper-function-name@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/helper-function-name/-/helper-function-name-7.0.0-beta.44.tgz#e18552aaae2231100a6e485e03854bc3532d44dd"
+  integrity sha512-MHRG2qZMKMFaBavX0LWpfZ2e+hLloT++N7rfM3DYOMUOGCD8cVjqZpwiL8a0bOX3IYcQev1ruciT0gdFFRTxzg==
+  dependencies:
+    "@babel/helper-get-function-arity" "7.0.0-beta.44"
+    "@babel/template" "7.0.0-beta.44"
+"@babel/helper-get-function-arity@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/helper-get-function-arity/-/helper-get-function-arity-7.0.0-beta.44.tgz#d03ca6dd2b9f7b0b1e6b32c56c72836140db3a15"
+  integrity sha512-w0YjWVwrM2HwP6/H3sEgrSQdkCaxppqFeJtAnB23pRiJB5E/O9Yp7JAAeWBl+gGEgmBFinnTyOv2RN7rcSmMiw==
+  dependencies:
+"@babel/helper-split-export-declaration@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/helper-split-export-declaration/-/helper-split-export-declaration-7.0.0-beta.44.tgz#c0b351735e0fbcb3822c8ad8db4e583b05ebd9dc"
+  integrity sha512-aQ7QowtkgKKzPGf0j6u77kBMdUFVBKNHw2p/3HX/POt5/oz8ec5cs0GwlgM8Hz7ui5EwJnzyfRmkNF1Nx1N7aA==
+  dependencies:
+"@babel/highlight@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/highlight/-/highlight-7.0.0-beta.44.tgz#18c94ce543916a80553edcdcf681890b200747d5"
+  integrity sha512-Il19yJvy7vMFm8AVAh6OZzaFoAd0hbkeMZiX3P5HGD+z7dyI7RzndHB0dg6Urh/VAFfHtpOIzDUSxmY6coyZWQ==
+  dependencies:
+    chalk "^2.0.0"
+    esutils "^2.0.2"
+    js-tokens "^3.0.0"
+"@babel/template@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/template/-/template-7.0.0-beta.44.tgz#f8832f4fdcee5d59bf515e595fc5106c529b394f"
+  integrity sha512-w750Sloq0UNifLx1rUqwfbnC6uSUk0mfwwgGRfdLiaUzfAOiH0tHJE6ILQIUi3KYkjiCDTskoIsnfqZvWLBDng==
+  dependencies:
+    "@babel/code-frame" "7.0.0-beta.44"
+    babylon "7.0.0-beta.44"
+    lodash "^4.2.0"
+"@babel/traverse@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/traverse/-/traverse-7.0.0-beta.44.tgz#a970a2c45477ad18017e2e465a0606feee0d2966"
+  integrity sha512-UHuDz8ukQkJCDASKHf+oDt3FVUzFd+QYfuBIsiNu/4+/ix6pP/C+uQZJ6K1oEfbCMv/IKWbgDEh7fcsnIE5AtA==
+  dependencies:
+    "@babel/generator" "7.0.0-beta.44"
+    "@babel/helper-function-name" "7.0.0-beta.44"
+    "@babel/helper-split-export-declaration" "7.0.0-beta.44"
+    debug "^3.1.0"
+    globals "^11.1.0"
+    invariant "^2.2.0"
+    lodash "^4.2.0"
+"@babel/types@7.0.0-beta.44":
+  resolved "https://registry.yarnpkg.com/@babel/types/-/types-7.0.0-beta.44.tgz#6b1b164591f77dec0a0342aca995f2d046b3a757"
+  integrity sha512-5eTV4WRmqbaFM3v9gHAIljEQJU4Ssc6fxL61JN+Oe2ga/BwyjzjamwkCVVAQjHGuAX8i0BWo42dshL8eO5KfLQ==
+  dependencies:
+    esutils "^2.0.2"
+    lodash "^4.2.0"
+    to-fast-properties "^2.0.0"
+acorn-jsx@^3.0.0:
+  version "3.0.1"
+  resolved "https://registry.yarnpkg.com/acorn-jsx/-/acorn-jsx-3.0.1.tgz#afdf9488fb1ecefc8348f6fb22f464e32a58b36b"
+  integrity sha1-r9+UiPsezvyDSPb7IvRk4ypYs2s=
+  dependencies:
+    acorn "^3.0.4"
+acorn@^3.0.4:
+  version "3.3.0"
+  resolved "https://registry.yarnpkg.com/acorn/-/acorn-3.3.0.tgz#45e37fb39e8da3f25baee3ff5369e2bb5f22017a"
+  integrity sha1-ReN/s56No/JbruP/U2niu18iAXo=
+acorn@^5.5.0:
+  version "5.7.4"
+  resolved "https://registry.yarnpkg.com/acorn/-/acorn-5.7.4.tgz#3e8d8a9947d0599a1796d10225d7432f4a4acf5e"
+  integrity sha512-1D++VG7BhrtvQpNbBzovKNc1FLGGEE/oGe7b9xJm/RFHMBeUaUGpluV9RLjZa47YFdPcDAenEYuq9pQPcMdLJg==
+ajv-keywords@^2.1.0:
+  version "2.1.1"
+  resolved "https://registry.yarnpkg.com/ajv-keywords/-/ajv-keywords-2.1.1.tgz#617997fc5f60576894c435f940d819e135b80762"
+  integrity sha1-YXmX/F9gV2iUxDX5QNgZ4TW4B2I=
+ajv@^5.2.3, ajv@^5.3.0:
+  version "5.5.2"
+  resolved "https://registry.yarnpkg.com/ajv/-/ajv-5.5.2.tgz#73b5eeca3fab653e3d3f9422b341ad42205dc965"
+  integrity sha1-c7Xuyj+rZT49P5Qis0GtQiBdyWU=
+  dependencies:
+    co "^4.6.0"
+    fast-deep-equal "^1.0.0"
+    fast-json-stable-stringify "^2.0.0"
+    json-schema-traverse "^0.3.0"
+ansi-escapes@^3.0.0:
+  version "3.2.0"
+  resolved "https://registry.yarnpkg.com/ansi-escapes/-/ansi-escapes-3.2.0.tgz#8780b98ff9dbf5638152d1f1fe5c1d7b4442976b"
+  integrity sha512-cBhpre4ma+U0T1oM5fXg7Dy1Jw7zzwv7lt/GoCpr+hDQJoYnKVPLL4dCvSEFMmQurOQvSrwT7SL/DAlhBI97RQ==
+ansi-regex@^2.0.0:
+  version "2.1.1"
+  resolved "https://registry.yarnpkg.com/ansi-regex/-/ansi-regex-2.1.1.tgz#c3b33ab5ee360d86e0e628f0468ae7ef27d654df"
+  integrity sha1-w7M6te42DYbg5ijwRorn7yfWVN8=
+ansi-regex@^3.0.0:
+  version "3.0.0"
+  resolved "https://registry.yarnpkg.com/ansi-regex/-/ansi-regex-3.0.0.tgz#ed0317c322064f79466c02966bddb605ab37d998"
+  integrity sha1-7QMXwyIGT3lGbAKWa922Bas32Zg=
+ansi-styles@^2.2.1:
+  version "2.2.1"
+  resolved "https://registry.yarnpkg.com/ansi-styles/-/ansi-styles-2.2.1.tgz#b432dd3358b634cf75e1e4664368240533c1ddbe"
+  integrity sha1-tDLdM1i2NM914eRmQ2gkBTPB3b4=
+ansi-styles@^3.2.1:
+  version "3.2.1"
+  resolved "https://registry.yarnpkg.com/ansi-styles/-/ansi-styles-3.2.1.tgz#41fbb20243e50b12be0f04b8dedbf07520ce841d"
+  integrity sha512-VT0ZI6kZRdTh8YyJw3SMbYm/u+NqfsAxEpWO0Pf9sq8/e94WxxOpPKx9FR1FlyCtOVDNOQ+8ntlqFxiRc+r5qA==
+  dependencies:
+    color-convert "^1.9.0"
+argparse@^1.0.7:
+  version "1.0.10"
+  resolved "https://registry.yarnpkg.com/argparse/-/argparse-1.0.10.tgz#bcd6791ea5ae09725e17e5ad988134cd40b3d911"
GitHub sha: bbf598b9
