FIX: 'local_cdn_url' method should work for local relative urls too.
FIX: ‘local_cdn_url’ method should work for local relative urls too.
diff --git a/lib/url_helper.rb b/lib/url_helper.rb
index 0c69d28782..b156013295 100644
--- a/lib/url_helper.rb
+++ b/lib/url_helper.rb
@@ -71,7 +71,11 @@ class UrlHelper
   def self.local_cdn_url(url)
     return url if Discourse.asset_host.blank?
-    url.sub(Discourse.base_url_no_prefix, Discourse.asset_host)
+    if url.start_with?("/#{Discourse.store.upload_path}/")
+      "#{Discourse.asset_host}#{url}"
+    else
+      url.sub(Discourse.base_url_no_prefix, Discourse.asset_host)
+    end
diff --git a/spec/components/url_helper_spec.rb b/spec/components/url_helper_spec.rb
index 53da4a688d..77ae944249 100644
--- a/spec/components/url_helper_spec.rb
+++ b/spec/components/url_helper_spec.rb
@@ -119,4 +119,15 @@ describe UrlHelper do
+  describe "#local_cdn_url" do
+    let(:url) { "/uploads/default/1X/575bcc2886bf7a39684b57ca90be85f7d399bbc7.png" }
+    let(:asset_host) { "//my.awesome.cdn" }
+    it "should return correct cdn url for local relative urls" do
+      Discourse.stubs(:asset_host).returns(asset_host)
+      cdn_url = UrlHelper.local_cdn_url(url)
+      expect(cdn_url).to eq("#{asset_host}#{url}")
+    end
+  end
GitHub sha: f92a6f7a
