FIX: log proper error message when SSO nonce verification fails (#14077)
diff --git a/app/controllers/session_controller.rb b/app/controllers/session_controller.rb
index 5857416..1f09922 100644
--- a/app/controllers/session_controller.rb
+++ b/app/controllers/session_controller.rb
@@ -156,7 +156,7 @@ class SessionController < ApplicationController
     if !sso.nonce_valid?
       if SiteSetting.verbose_discourse_connect_logging
-        Rails.logger.warn("Verbose SSO log: Nonce has already expired\n\n#{sso.diagnostics}")
+        Rails.logger.warn("Verbose SSO log: #{sso.nonce_error}\n\n#{sso.diagnostics}")
       return render_sso_error(text: I18n.t("discourse_connect.timeout_expired"), status: 419)
diff --git a/app/models/discourse_single_sign_on.rb b/app/models/discourse_single_sign_on.rb
index 7be3b50..b30286f 100644
--- a/app/models/discourse_single_sign_on.rb
+++ b/app/models/discourse_single_sign_on.rb
@@ -47,6 +47,14 @@ class DiscourseSingleSignOn < SingleSignOn
+  def nonce_error
+    if Discourse.cache.read(used_nonce_key).present?
+      "Nonce has already been used"
+    else
+      "Nonce has expired"
+    end
+  end
   def return_path
     if SiteSetting.discourse_connect_csrf_protection
       @secure_session[nonce_key] || "/"
@@ -62,6 +70,8 @@ class DiscourseSingleSignOn < SingleSignOn
       else
         Discourse.cache.delete nonce_key
+      Discourse.cache.write(used_nonce_key, return_path, expires_in: SingleSignOn.used_nonce_expiry_time)
@@ -69,6 +79,10 @@ class DiscourseSingleSignOn < SingleSignOn
     "SSO_NONCE_#{nonce}"
+  def used_nonce_key
+    "USED_SSO_NONCE_#{nonce}"
+  end
   BANNED_EXTERNAL_IDS = %w{none nil blank null}
   def lookup_or_create_user(ip_address = nil)
diff --git a/lib/single_sign_on.rb b/lib/single_sign_on.rb
index a4c0bab..3cdfff0 100644
--- a/lib/single_sign_on.rb
+++ b/lib/single_sign_on.rb
@@ -50,6 +50,10 @@ class SingleSignOn
     @nonce_expiry_time = v
+  def self.used_nonce_expiry_time
+    24.hours
+  end
   attr_accessor(*ACCESSORS)
   attr_writer :sso_secret, :sso_url
diff --git a/spec/models/discourse_single_sign_on_spec.rb b/spec/models/discourse_single_sign_on_spec.rb
index e1d03c1..c909565 100644
--- a/spec/models/discourse_single_sign_on_spec.rb
+++ b/spec/models/discourse_single_sign_on_spec.rb
@@ -406,6 +406,28 @@ describe DiscourseSingleSignOn do
     expect(sso.nonce).to_not be_nil
+  context 'nonce error' do
+    it "generates correct error message when nonce has already been used" do
+      _ , payload = DiscourseSingleSignOn.generate_url(secure_session: secure_session).split("?")
+      sso = DiscourseSingleSignOn.parse(payload, secure_session: secure_session)
+      expect(sso.nonce_valid?).to eq true
+      sso.expire_nonce!
+      expect(sso.nonce_error).to eq("Nonce has already been used")
+    end
+    it "generates correct error message when nonce is expired" do
+      Discourse.cache.delete(sso.used_nonce_key)
+      expect(sso.nonce_error).to eq("Nonce has expired")
+    end
+  end
   context 'user locale' do
     it 'sets default user locale if specified' do
       SiteSetting.allow_user_locale = true
GitHub sha: 7db3888f17ec07800e1aba0b5470bb9efe73a670
This commit appears in #14077 which was approved by CvX. It was merged by techAPJ.
