FIX: logs for enabling/disabling components should show up in the staff actions logs
diff --git a/app/models/user_history.rb b/app/models/user_history.rb
index c632a3c..0c5d87d 100644
--- a/app/models/user_history.rb
+++ b/app/models/user_history.rb
@@ -169,7 +169,9 @@ class UserHistory < ActiveRecord::Base
       :embeddable_host_create,
       :embeddable_host_update,
       :embeddable_host_destroy,
-      :change_theme_setting
+      :change_theme_setting,
+      :disable_theme_component,
+      :enable_theme_component
diff --git a/config/locales/client.en.yml b/config/locales/client.en.yml
index 2c45ac5..de60aa5 100644
--- a/config/locales/client.en.yml
+++ b/config/locales/client.en.yml
@@ -3801,6 +3801,8 @@ en:
             embeddable_host_update: "embeddable host update"
             embeddable_host_destroy: "embeddable host destroy"
             change_theme_setting: "change theme setting"
+            disable_theme_component: "disable theme component"
+            enable_theme_component: "enable theme component"
         screened_emails:
           title: "Screened Emails"
           description: "When someone tries to create a new account, the following email addresses will be checked and the registration will be blocked, or some other action performed."
GitHub sha: 426c8045
