FIX: Make email_valid handling consistent (#11556)
Previously we were checking truthiness in some places, and == true in others. That can lead to some inconsistent UX where the interface says the email is valid, but account creation fails.
This commit ensures values are boolean when set, and raises an error for other value types.
If this safety check is triggered, it means the specific auth provider needs to be updated to pass booleans.
diff --git a/app/services/user_authenticator.rb b/app/services/user_authenticator.rb
index 5db04fa..822c9b5 100644
--- a/app/services/user_authenticator.rb
+++ b/app/services/user_authenticator.rb
@@ -41,7 +41,7 @@ class UserAuthenticator
   def authenticated?
     return false if !@auth_result
     return false if @auth_result&.email&.downcase != @user.email.downcase
-    return false if @auth_result.email_valid != true # strong check for truth, in case we have another object type
+    return false if !@auth_result.email_valid
     true
diff --git a/lib/auth/result.rb b/lib/auth/result.rb
index 5cad431..6abbdeb 100644
--- a/lib/auth/result.rb
+++ b/lib/auth/result.rb
@@ -52,6 +52,13 @@ class Auth::Result
     @email&.downcase
+  def email_valid=(val)
+    if !val.in? [true, false, nil]
+      raise ArgumentError, "email_valid should be boolean or nil"
+    end
+    @email_valid = !!val
+  end
   def failed?
     !!@failed
diff --git a/spec/services/user_authenticator_spec.rb b/spec/services/user_authenticator_spec.rb
index 5db539d..07cce90 100644
--- a/spec/services/user_authenticator_spec.rb
+++ b/spec/services/user_authenticator_spec.rb
@@ -66,5 +66,14 @@ describe UserAuthenticator do
       expect(session[:authentication]).to eq(nil)
+    it "raises an error for non-boolean values" do
+      user = Fabricate(:user, email: "user53@discourse.org")
+      session = { authentication: github_auth('string') }
+      expect do
+        UserAuthenticator.new(user, session).finish
+      end.to raise_error ArgumentError
+    end
GitHub sha: a040f72f
This commit appears in #11556 which was approved by CvX. It was merged by davidtaylorhq.
