FIX: Make site tasks work with duplicated uploads (#13972)
Uploads can be reused between site settings. This change allows the same upload to be exported only once and then the same file is reused. The same applies to import.
diff --git a/lib/tasks/site.rake b/lib/tasks/site.rake
index 87ac822..ba984bd 100644
--- a/lib/tasks/site.rake
+++ b/lib/tasks/site.rake
@@ -8,6 +8,7 @@ class ZippedSiteStructure
   def initialize(path, create: false)
     @zip = Zip::File.open(path, create)
+    @uploads = {}
   def close
@@ -41,26 +42,53 @@ class ZippedSiteStructure
       return nil
+    if @uploads[upload.id].present?
+      puts "  - Already exported upload #{upload_or_id_or_url} to #{@uploads[upload.id][:path]}"
+      return @uploads[upload.id]
+    end
     local_path = upload.local? ? Discourse.store.path_for(upload) : Discourse.store.download(upload).path
     zip_path = File.join('uploads', File.basename(local_path))
+    zip_path = get_unique_path(zip_path)
     puts "  - Exporting upload #{upload_or_id_or_url} to #{zip_path}"
     @zip.add(zip_path, local_path)
-    { filename: upload.original_filename, path: zip_path }
+    @uploads[upload.id] ||= { filename: upload.original_filename, path: zip_path }
   def get_upload(upload, opts = {})
     return nil if upload.blank?
+    if @uploads[upload['path']].present?
+      puts "  - Already imported upload #{upload['filename']} from #{upload['path']}"
+      return @uploads[upload['path']]
+    end
     puts "  - Importing upload #{upload['filename']} from #{upload['path']}"
     tempfile = Tempfile.new(upload['filename'], binmode: true)
     tempfile.write(@zip.get_input_stream(upload['path']).read)
     tempfile.rewind
-    UploadCreator.new(tempfile, upload['filename'], opts)
-      .create_for(Discourse::SYSTEM_USER_ID)
+    @uploads[upload['path']] ||= UploadCreator.new(tempfile, upload['filename'], opts).create_for(Discourse::SYSTEM_USER_ID)
+  end
+  private
+  def get_unique_path(path)
+    return path if @zip.find_entry(path).blank?
+    extname = File.extname(path)
+    basename = File.basename(path, extname)
+    dirname = File.dirname(path)
+    i = 0
+    loop do
+      i += 1
+      path = File.join(dirname, "#{basename}_#{i}#{extname}")
+    end
GitHub sha: 4380ba34d5d83ee05cb8bf2057882de9efde1362
This commit appears in #13972 which was approved by eviltrout. It was merged by nbianca.
