FIX: Make storage detection compatible with docker 19.x
diff --git a/launcher b/launcher
index 6a71521..97628a1 100755
--- a/launcher
+++ b/launcher
@@ -153,7 +153,7 @@ check_prereqs() {
   fi
   # 2. running an approved storage driver?
-  if ! $docker_path info 2> /dev/null | egrep -q '^Storage Driver: (aufs|zfs|overlay2)$'; then
+  if ! $docker_path info 2> /dev/null | egrep -q 'Storage Driver: (aufs|zfs|overlay2)$'; then
     echo "Your Docker installation is not using a supported storage driver.  If we were to proceed you may have a broken install."
     echo "aufs is the recommended storage driver, although zfs and overlay2 may work as well."
     echo "Other storage drivers are known to be problematic."
GitHub sha: 98c5fec4
https://meta.discourse.org/t/bootstrapping-fails-because-filesystem-check-regex-doesnt-match/119625/7
hi, I think it’s not a bug, and you cause a bug. docker 18.x 19.x can’t check on centos
hi, actually, this problem happened on docker 18.x too.
