FIX: Make the `verbose_auth_token_logging` setting off by default (#14664)
FIX: Make the verbose_auth_token_logging setting off by default (#14664)
The generate, rotate and suspicious auth token logs are now always logged regardless of the verbose_auth_token_logging setting because we rely no these to detect suspicious logins.
diff --git a/app/models/user_auth_token.rb b/app/models/user_auth_token.rb
index 99dc339..5cb107c 100644
--- a/app/models/user_auth_token.rb
+++ b/app/models/user_auth_token.rb
@@ -15,17 +15,23 @@ class UserAuthToken < ActiveRecord::Base
   attr_accessor :unhashed_auth_token
   before_destroy do
-    UserAuthToken.log(action: 'destroy',
-                      user_auth_token_id: self.id,
-                      user_id: self.user_id,
-                      user_agent: self.user_agent,
-                      client_ip: self.client_ip,
-                      auth_token: self.auth_token)
+    UserAuthToken.log_verbose(
+      action: 'destroy',
+      user_auth_token_id: self.id,
+      user_id: self.user_id,
+      user_agent: self.user_agent,
+      client_ip: self.client_ip,
+      auth_token: self.auth_token,
   def self.log(info)
+    UserAuthTokenLog.create!(info)
+  end
+  def self.log_verbose(info)
     if SiteSetting.verbose_auth_token_logging
-      UserAuthTokenLog.create!(info)
+      log(info)
@@ -78,13 +84,15 @@ class UserAuthToken < ActiveRecord::Base
     user_auth_token.unhashed_auth_token = token
-    log(action: 'generate',
-        user_auth_token_id: user_auth_token.id,
-        user_id: user_id,
-        user_agent: user_agent,
-        client_ip: client_ip,
-        path: path,
-        auth_token: hashed_token)
+    log(
+      action: 'generate',
+      user_auth_token_id: user_auth_token.id,
+      user_id: user_id,
+      user_agent: user_agent,
+      client_ip: client_ip,
+      path: path,
+      auth_token: hashed_token,
     if staff && !impersonate
       Jobs.enqueue(:suspicious_login,
@@ -108,12 +116,14 @@ class UserAuthToken < ActiveRecord::Base
     if !user_token
-      log(action: "miss token",
-          user_id: user_token&.user_id,
-          auth_token: token,
-          user_agent: opts && opts[:user_agent],
-          path: opts && opts[:path],
-          client_ip: opts && opts[:client_ip])
+      log_verbose(
+        action: "miss token",
+        user_id: nil,
+        auth_token: token,
+        user_agent: opts && opts[:user_agent],
+        path: opts && opts[:path],
+        client_ip: opts && opts[:client_ip],
       return nil
@@ -126,7 +136,7 @@ class UserAuthToken < ActiveRecord::Base
       # not updating AR model cause we want to give it one more req
       # with wrong cookie
         action: changed_rows == 0 ? "prev seen token unchanged" : "prev seen token",
         user_auth_token_id: user_token.id,
         user_id: user_token.user_id,
@@ -149,13 +159,15 @@ class UserAuthToken < ActiveRecord::Base
         user_token.seen_at = Time.zone.now
-      log(action: changed_rows == 0 ? "seen wrong token" : "seen token",
-          user_auth_token_id: user_token.id,
-          user_id: user_token.user_id,
-          auth_token: user_token.auth_token,
+      log_verbose(
+        action: changed_rows == 0 ? "seen wrong token" : "seen token",
+        user_auth_token_id: user_token.id,
+        user_id: user_token.user_id,
+        auth_token: user_token.auth_token,
     user_token
diff --git a/config/site_settings.yml b/config/site_settings.yml
index 7fb7f10..107c4b9 100644
--- a/config/site_settings.yml
+++ b/config/site_settings.yml
@@ -465,7 +465,7 @@ login:
     default: false
   verbose_auth_token_logging:
     hidden: true
-    default: true
+    default: false
   max_suspicious_distance_km:
     hidden: true
     default: 500
GitHub sha: 8fb823c30f7fd3086f4370c2dc6e4e3737ae6acf
This commit appears in #14664 which was approved by ZogStriP. It was merged by OsamaSayegh.
