FIX: Migrate post_edit_time_limit to tl2_post_edit_time_limit (PR #8082)
Insert new value into tl2_post_edit_time_limit if:
  • tl2 setting does not exist
  • tl0 setting is larger than default tl2
  • Uses current timestamp
  • No rollback
GitHub
You’ve signed the CLA, rimian. Thank you! This pull request is ready for review.
I don’t think we need this cast, we can just insert unconditionally, that way post upgrade everything will work exactly as it used to if you did any overriding.
This looks great, thank Rim
This pull request has been mentioned on Discourse Meta. There might be relevant details there:
