Fix minor typo.
Fix minor typo.
diff --git a/README.md b/README.md
index 352c246..3d88b14 100644
--- a/README.md
+++ b/README.md
@@ -22,4 +22,4 @@ These custom fields are available when a plugin event is triggered.
 #### Holidays
 To add/remove/correct a holiday, edit the relevant [definition files](vendor/holidays/definitions) and run `rake generate:definitions` in the `vendor/holidays`
-directory. Syntax of definition files can be found in [vendor/holidays/definitions/docks/SYNTAX.md](vendor/holidays/definitions/docks/SYNTAX.md).
+directory. Syntax of definition files can be found in [vendor/holidays/definitions/docks/SYNTAX.md](vendor/holidays/definitions/docs/SYNTAX.md).
GitHub sha: ba238b8d
