FIX: More 404 image requests in test
A few tests were removed that were testing a subforum for the logo, which I don’t think gain us much anymore. We use getURL everywhere and needn’t test it so much. Plus, over time it’s always good to remove a few tests here and there :slight_smile:
diff --git a/test/javascripts/components/image-uploader-test.js b/test/javascripts/components/image-uploader-test.js
index 4ef3f1e..7da9744 100644
--- a/test/javascripts/components/image-uploader-test.js
+++ b/test/javascripts/components/image-uploader-test.js
@@ -3,7 +3,7 @@ moduleForComponent("image-uploader", { integration: true });
 componentTest("with image", {
   template:
-    "{{image-uploader imageUrl='/some/upload.png' placeholderUrl='/not/used.png'}}",
+    "{{image-uploader imageUrl='/images/avatar.png' placeholderUrl='/not/used.png'}}",
   async test(assert) {
     assert.equal(
diff --git a/test/javascripts/lib/pretty-text-test.js b/test/javascripts/lib/pretty-text-test.js
index 393b037..5ab9895 100644
--- a/test/javascripts/lib/pretty-text-test.js
+++ b/test/javascripts/lib/pretty-text-test.js
@@ -1519,20 +1519,20 @@ QUnit.test("emoji - emojiSet", assert => {
 QUnit.test("emoji - registerEmoji", assert => {
-  registerEmoji("foo", "/foo.png");
+  registerEmoji("foo", "/images/d-logo-sketch.png");
   assert.cookedOptions(
     ":foo:",
-    `<p><img src="/foo.png?v=${v}" title=":foo:" class="emoji emoji-custom only-emoji" alt=":foo:"></p>`
+    `<p><img src="/images/d-logo-sketch.png?v=${v}" title=":foo:" class="emoji emoji-custom only-emoji" alt=":foo:"></p>`
-  registerEmoji("bar", "/bar.png", "baz");
+  registerEmoji("bar", "/images/avatar.png", "baz");
     ":bar:",
-    `<p><img src="/bar.png?v=${v}" title=":bar:" class="emoji emoji-custom only-emoji" alt=":bar:"></p>`
+    `<p><img src="/images/avatar.png?v=${v}" title=":bar:" class="emoji emoji-custom only-emoji" alt=":bar:"></p>`
diff --git a/test/javascripts/widgets/home-logo-test.js b/test/javascripts/widgets/home-logo-test.js
index c30c1a5..14b32a3 100644
--- a/test/javascripts/widgets/home-logo-test.js
+++ b/test/javascripts/widgets/home-logo-test.js
@@ -1,6 +1,4 @@
 import { moduleForWidget, widgetTest } from "helpers/widget-test";
-import { setPrefix } from "discourse-common/lib/get-url";
 moduleForWidget("home-logo");
 const bigLogo = "/images/d-logo-sketch.png?test";
@@ -98,52 +96,3 @@ widgetTest("mobile without logo", {
     assert.equal(find("#site-logo").attr("src"), bigLogo);
-widgetTest("basics, subfolder", {
-  template: '{{mount-widget widget="home-logo" args=args}}',
-  beforeEach() {
-    setPrefix("/forum");
-    this.siteSettings.site_logo_url = bigLogo;
-    this.siteSettings.site_logo_small_url = smallLogo;
-    this.siteSettings.title = title;
-    this.set("args", { minimized: false });
-  test(assert) {
-    assert.ok(find("img#site-logo.logo-big").length === 1);
-    assert.equal(find("#site-logo").attr("src"), `/forum${bigLogo}`);
-    assert.equal(find("#site-logo").attr("alt"), title);
-widgetTest("basics, subfolder - minimized", {
-  beforeEach() {
-    this.set("args", { minimized: true });
-  test(assert) {
-    assert.ok(find("img.logo-small").length === 1);
-    assert.equal(find("img.logo-small").attr("src"), `/forum${smallLogo}`);
-    assert.equal(find("img.logo-small").attr("alt"), title);
-widgetTest("mobile logo, subfolder", {
-  beforeEach() {
-    this.siteSettings.site_mobile_logo_url = mobileLogo;
-    this.site.mobileView = true;
-  test(assert) {
-    assert.equal(find("#site-logo").attr("src"), `/forum${mobileLogo}`);
GitHub sha: 2a4a2a2a
