FIX: `mouseEnter` is deprecated in newer Ember releases
FIX: mouseEnter is deprecated in newer Ember releases
This is the recommended fix via: https://deprecations.emberjs.com/v3.x/#toc_component-mouseenter-leave-move
diff --git a/app/assets/javascripts/select-kit/addon/components/select-kit/select-kit-row.js b/app/assets/javascripts/select-kit/addon/components/select-kit/select-kit-row.js
index d273974..30ed72f 100644
--- a/app/assets/javascripts/select-kit/addon/components/select-kit/select-kit-row.js
+++ b/app/assets/javascripts/select-kit/addon/components/select-kit/select-kit-row.js
@@ -1,6 +1,6 @@
 import I18n from "I18n";
 import Component from "@ember/component";
-import { computed } from "@ember/object";
+import { computed, action } from "@ember/object";
 import { makeArray } from "discourse-common/lib/helpers";
 import { guidFor } from "@ember/object/internals";
 import UtilsMixin from "select-kit/mixins/utils";
@@ -27,6 +27,18 @@ export default Component.extend(UtilsMixin, {
     "item.classNames",
+  didInsertElement() {
+    this._super(...arguments);
+    this.element.addEventListener("mouseenter", this.handleMouseEnter);
+  willDestroyElement() {
+    if (this.element) {
+      this.element.removeEventListener("mouseenter", this.handleMouseEnter);
   isNone: computed("rowValue", function () {
     return this.rowValue === this.getValue(this.selectKit.noneItem);
@@ -91,7 +103,8 @@ export default Component.extend(UtilsMixin, {
     return this.rowValue === this.value;
-  mouseEnter() {
+  @action
+  handleMouseEnter() {
     if (!this.isDestroying || !this.isDestroyed) {
       this.selectKit.onHover(this.rowValue, this.item);
GitHub sha: c5a2de99
This commit appears in #10706 which was approved by jjaffeux and CvX. It was merged by eviltrout.
