FIX: Move rake tasks into their own file and class
Rake::Task.clear called by the other plugins in rake plugin:spec clears these dynamically defined tasks, so I moved them into their own class so we can call DiscourseCodeReview::RakeTasks.define_tasks to reload them in the spec.
Confirmed this works now with rake plugin:spec and also rake --tasks -A
index e27eca0..068e21c 100644
--- a/plugin.rb
+++ b/plugin.rb
@@ -24,6 +24,7 @@ register_svg_icon 'history'
 require_dependency 'auth/github_authenticator'
 require_dependency 'lib/staff_constraint'
+require File.expand_path("../lib/discourse_code_review/rake_tasks.rb", __FILE__)
 module HackGithubAuthenticator
   def after_authenticate(auth_token, existing_account: nil)
@@ -305,70 +306,4 @@ after_initialize do
-Rake::Task.define_task code_review_delete_user_github_access_tokens: :environment do
-  num_deleted = UserCustomField.where(name: 'github user token').delete_all
-  puts "deleted #{num_deleted} user_custom_fields"
-end
-Rake::Task.define_task code_review_tag_commits: :environment do
-  topics =
-    Topic
-      .where(
-        id:
-          TopicCustomField
-            .select(:topic_id)
-            .where(name: DiscourseCodeReview::COMMIT_HASH)
-      .to_a
-  puts "Tagging #{topics.size} topics"
-  topics.each do |topic|
-    DiscourseTagging.tag_topic_by_names(
-      topic,
-      Discourse.system_user.guardian,
-      [SiteSetting.code_review_commit_tag],
-      append: true
-  end
-end
-Rake::Task.define_task code_review_full_sha_backfill: :environment do
-  posts_with_commit = Post
-    .joins("INNER JOIN topics ON topics.id = posts.topic_id")
-    .joins("INNER JOIN topic_custom_fields ON topics.id = topic_custom_fields.topic_id")
-    .includes(topic: :_custom_fields)
-    .where("topic_custom_fields.name = '#{DiscourseCodeReview::COMMIT_HASH}' AND
-            topics.deleted_at IS NULL AND
-            posts.deleted_at IS NULL AND
-            posts.post_number = 1 AND
-            posts.raw ~ 'sha: [0-9a-f]{6,10}' AND
-            posts.raw !~ 'sha: [0-9a-f]{11,60}'")
-  total = posts_with_commit.count
-  incr = 0
-  puts "Found #{total} posts with a commit sha from the discourse-code-review plugin."
-  posts_with_commit.find_each do |post_with_commit|
-    puts "Replacing sha in post #{post_with_commit.id}..."
-    full_git_sha = post_with_commit.topic.custom_fields[DiscourseCodeReview::COMMIT_HASH]
-    new_raw = post_with_commit.raw.gsub(/sha: [0-9a-f]{6,10}\b/, "sha: #{full_git_sha}")
-    if new_raw == post_with_commit.raw
-      puts "Nothing to change for post #{post_with_commit.id}, continuing. (new raw same as old raw)"
-      incr += 1
-      puts "Completed #{incr}/#{total}."
-      next
-    end
-    post_with_commit.update(raw: new_raw)
-    post_with_commit.rebake!
-    incr += 1
-  end
-  puts "All complete."
-end
+DiscourseCodeReview::RakeTasks.define_tasks
diff --git a/spec/lib/tasks/code_review_sha_backfill_spec.rb b/spec/lib/tasks/code_review_sha_backfill_spec.rb
index 328287a..8046596 100644
--- a/spec/lib/tasks/code_review_sha_backfill_spec.rb
+++ b/spec/lib/tasks/code_review_sha_backfill_spec.rb
@@ -4,7 +4,9 @@ require 'rails_helper'
 describe "tasks/code_review_sha_backfill" do
   before do
+    Rake::Task.clear
     Discourse::Application.load_tasks
+    DiscourseCodeReview::RakeTasks.define_tasks
   def raw
GitHub sha: ea83e7dc
