FIX: Move read state when moving posts (PR #8056)
  • Moves / copies post timings
  • Moves / copies topic users
  • Fixes a small bug in the calculation of post numbers
GitHub
You’ve signed the CLA, gschlager. Thank you! This pull request is ready for review.
The lowest priority imaginable here, but the indentation here is severe :slight_smile:
That central query is a bit of a monster. However moving posts is a somewhat uncommon operation so it should be fine, and there is a lot of coverage.
Thanks for reviewing. I tweaked the indentation a little bit. :slight_smile:
