FIX: Narration Bot now gets site setting for automatic post deletion (#7432)
diff --git a/plugins/discourse-narrative-bot/config/locales/server.en.yml b/plugins/discourse-narrative-bot/config/locales/server.en.yml
index 00b1bf1..93a42b9 100644
--- a/plugins/discourse-narrative-bot/config/locales/server.en.yml
+++ b/plugins/discourse-narrative-bot/config/locales/server.en.yml
@@ -366,7 +366,7 @@ en:
         reply: |-
           Phew, that was a close one! Thanks for fixing that :wink:
-          Do note that you only have 24 hours to undelete a post.
+          Do note that you only have %{deletion_after} hour(s) to undelete a post.
       category_hashtag:
         instructions: |-
diff --git a/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/advanced_user_narrative.rb b/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/advanced_user_narrative.rb
index 7f991f0..6f661e9 100644
--- a/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/advanced_user_narrative.rb
+++ b/plugins/discourse-narrative-bot/lib/discourse_narrative_bot/advanced_user_narrative.rb
@@ -249,7 +249,7 @@ module DiscourseNarrativeBot
       fake_delay
       raw = <<~RAW
-      #{I18n.t("#{I18N_KEY}.recover.reply", i18n_post_args)}
+      #{I18n.t("#{I18N_KEY}.recover.reply", i18n_post_args(deletion_after: SiteSetting.delete_removed_posts_after))}
       #{instance_eval(&@next_instructions)}
       RAW
diff --git a/plugins/discourse-narrative-bot/spec/discourse_narrative_bot/advanced_user_narrative_spec.rb b/plugins/discourse-narrative-bot/spec/discourse_narrative_bot/advanced_user_narrative_spec.rb
index 4b44326..62cc953 100644
--- a/plugins/discourse-narrative-bot/spec/discourse_narrative_bot/advanced_user_narrative_spec.rb
+++ b/plugins/discourse-narrative-bot/spec/discourse_narrative_bot/advanced_user_narrative_spec.rb
@@ -390,7 +390,7 @@ RSpec.describe DiscourseNarrativeBot::AdvancedUserNarrative do
             .to change { Post.count }.by(1)
           expected_raw = <<~RAW
-          #{I18n.t('discourse_narrative_bot.advanced_user_narrative.recover.reply', base_uri: '')}
+          #{I18n.t('discourse_narrative_bot.advanced_user_narrative.recover.reply', base_uri: '', deletion_after: SiteSetting.delete_removed_posts_after)}
           #{I18n.t('discourse_narrative_bot.advanced_user_narrative.category_hashtag.instructions', category: "#a:b", base_uri: '')}
           RAW
GitHub sha: d5d784b9
