FIX: Never prune Docker volumes
system prune on older Docker releases will remove volumes. The accidental removal of container volumes may result in user data loss.
This patch should ensure that any users on Docker CE <17.06.1 benefit from the same, safer behaviour enjoyed by users on contemporary Docker releases.
diff --git a/launcher b/launcher
index b94284f..7fb6ea9 100755
--- a/launcher
+++ b/launcher
@@ -235,7 +235,8 @@ check_prereqs() {
       echo
       if [[ $REPLY =~ ^[Yy]$ ]]
       then
-        $docker_path system prune -af
+        $docker_path container prune --force --filter until=1h >/dev/null
+        $docker_path image prune --all --force --filter until=1h >/dev/null
         echo "If the cleanup was successful, you may try again now"
       fi
     fi
@@ -469,7 +470,8 @@ if [ -z $docker_path ]; then
 fi
 [ "$command" == "cleanup" ] && {
+  $docker_path container prune --filter until=1h >/dev/null
+  $docker_path image prune --all --filter until=1h >/dev/null
   if [ -d /var/discourse/shared/standalone/postgres_data_old ]; then
     echo
GitHub sha: 70aaf454
