FIX: no_ads_for_tags support for hidden tags
Hidden tags aren’t sent to the client, so they couldn’t be used to disable ads on topic pages. Do this calculation on the server. Topic list pages for tags can continue to check on the client because non-staff get a 404 error when trying to view a hidden tag’s topic list.
diff --git a/assets/javascripts/discourse/components/ad-component.js.es6 b/assets/javascripts/discourse/components/ad-component.js.es6
index 660c681..7fa0aa5 100644
--- a/assets/javascripts/discourse/components/ad-component.js.es6
+++ b/assets/javascripts/discourse/components/ad-component.js.es6
@@ -13,18 +13,18 @@ export default Ember.Component.extend({
     "router.currentRoute.parent.attributes.category.slug"
+  // Server needs to compute this in case hidden tags are being used.
+  topicTagsDisableAds: Ember.computed.alias(
+    "router.currentRoute.parent.attributes.tags_disable_ads"
   @computed(
-    "router.currentRoute.parent.attributes.tags",
     "router.currentRoute.attributes.__type",
     "router.currentRoute.attributes.id"
-  currentTags(tagsArray, type, tag) {
-    if (tagsArray) {
-      return tagsArray;
+  topicListTag(type, tag) {
     if (type === "tag" && tag) {
-      return [tag];
+      return tag;
@@ -49,21 +49,19 @@ export default Ember.Component.extend({
     return !groupNames.any(g => noAdsGroupNames.includes(g));
-  @computed("currentCategoryId", "currentTags")
-  showOnCurrentPage(categoryId, currentTags) {
+  @computed("currentCategoryId", "topicTagsDisableAds", "topicListTag")
+  showOnCurrentPage(categoryId, topicTagsDisableAds, topicListTag) {
     return (
+      !topicTagsDisableAds &&
       (!categoryId ||
         !this.siteSettings.no_ads_for_categories ||
           .split("|")
           .includes(categoryId.toString())) &&
-      (!currentTags ||
+      (!topicListTag ||
         !this.siteSettings.no_ads_for_tags ||
-        Ember.isEmpty(
-          this.siteSettings.no_ads_for_tags
-            .split("|")
-            .filter(tag => currentTags.includes(tag))
+        !this.siteSettings.no_ads_for_tags.split("|").includes(topicListTag)
index 29e7528..fc63edc 100755
--- a/plugin.rb
+++ b/plugin.rb
@@ -39,6 +39,12 @@ after_initialize do
     AdPlugin::HouseAdSetting.settings_and_ads
+  add_to_serializer :topic_view, :tags_disable_ads do
+    return false if !SiteSetting.tagging_enabled || !SiteSetting.no_ads_for_tags.present?
+    return false if object.topic.tags.empty?
+    !(SiteSetting.no_ads_for_tags.split('|') & object.topic.tags.map(&:name)).empty?
+  end
   class ::AdstxtController < ::ApplicationController
     skip_before_action :check_xhr
GitHub sha: 92609c7a
