FIX: Only include pending/agreed scores in the total score
This should prevent posts from being hidden if a previous flag was rejected and a new one was added.
diff --git a/app/models/reviewable.rb b/app/models/reviewable.rb
index bebf710..1bdb587 100644
--- a/app/models/reviewable.rb
+++ b/app/models/reviewable.rb
@@ -465,29 +465,45 @@ class Reviewable < ActiveRecord::Base
 protected
   def recalculate_score
-    # Recalculate the pending score and return it
-    result = DB.query(<<~SQL, id: self.id, pending: ReviewableScore.statuses[:pending])
+    # pending/agreed scores count
+    sql = <<~SQL
       UPDATE reviewables
       SET score = COALESCE((
         SELECT sum(score)
         FROM reviewable_scores AS rs
         WHERE rs.reviewable_id = :id
+          AND rs.status IN (:pending, :agreed)
       ), 0.0)
       WHERE id = :id
       RETURNING score
     SQL
+    result = DB.query(
+      sql,
+      id: self.id,
+      pending: ReviewableScore.statuses[:pending],
+      agreed: ReviewableScore.statuses[:agreed]
     # Update topic score
-    DB.query(<<~SQL, topic_id: topic_id, pending: Reviewable.statuses[:pending])
+    sql = <<~SQL
       UPDATE topics
       SET reviewable_score = COALESCE((
         SELECT SUM(score)
         FROM reviewables AS r
         WHERE r.topic_id = :topic_id
+          AND r.status IN (:pending, :approved)
       ), 0.0)
       WHERE id = :topic_id
     SQL
+    DB.query(
+      sql,
+      topic_id: topic_id,
+      pending: Reviewable.statuses[:pending],
+      approved: Reviewable.statuses[:approved]
     self.score = result[0].score
diff --git a/spec/models/reviewable_score_spec.rb b/spec/models/reviewable_score_spec.rb
index 3072cd3..6a1c409 100644
--- a/spec/models/reviewable_score_spec.rb
+++ b/spec/models/reviewable_score_spec.rb
@@ -35,7 +35,7 @@ RSpec.describe ReviewableScore, type: :model do
       expect(rs.reload).to be_disagreed
       expect(rs.reviewed_by).to eq(moderator)
       expect(rs.reviewed_at).to be_present
-      expect(reviewable.score).to eq(4.0)
+      expect(reviewable.score).to eq(0.0)
     it "increases the score by the post action type's score bonus" do
GitHub sha: eedec7d7
