FIX: opening cancel draft dialog broke autosave
cancelComposer would leak a promise that never got resolved if you aborted cancelling a composer.
This change ensured the promise will always be resolved
diff --git a/app/assets/javascripts/discourse/app/controllers/composer.js b/app/assets/javascripts/discourse/app/controllers/composer.js
index f76b948..41fb94c 100644
--- a/app/assets/javascripts/discourse/app/controllers/composer.js
+++ b/app/assets/javascripts/discourse/app/controllers/composer.js
@@ -1043,8 +1043,8 @@ export default Controller.extend({
               if (differentDraft) {
                 this.model.clearState();
                 this.close();
-                resolve();
+              resolve();
@@ -1052,22 +1052,30 @@ export default Controller.extend({
             class: "btn-danger",
             callback: result => {
               if (result) {
-                this.destroyDraft().then(() => {
-                  this.model.clearState();
-                  this.close();
-                  resolve();
+                this.destroyDraft()
+                  .then(() => {
+                    this.model.clearState();
+                    this.close();
+                  .finally(() => {
+                    resolve();
+              } else {
+                resolve();
       } else {
         // it is possible there is some sort of crazy draft with no body ... just give up on it
-          this.close();
-          resolve();
+          .then(() => {
+            this.close();
+          .finally(() => {
+            resolve();
GitHub sha: f41fcad6
