FIX: Outsourced erb part from emoji.js.es6 (#7168)
approved
#1
diff --git a/app/assets/javascripts/pretty-text-bundle.js b/app/assets/javascripts/pretty-text-bundle.js
index 41324ba..ed5331b 100644
--- a/app/assets/javascripts/pretty-text-bundle.js
+++ b/app/assets/javascripts/pretty-text-bundle.js
@@ -2,6 +2,7 @@
 //= require ./pretty-text/guid
 //= require ./pretty-text/censored-words
 //= require ./pretty-text/emoji/data
+//= require ./pretty-text/emoji/version
 //= require ./pretty-text/engines/discourse-markdown-it
 //= require xss.min
diff --git a/app/assets/javascripts/pretty-text/emoji.js.es6 b/app/assets/javascripts/pretty-text/emoji.js.es6
new file mode 100644
index 0000000..5b48a64
--- /dev/null
+++ b/app/assets/javascripts/pretty-text/emoji.js.es6
@@ -0,0 +1,154 @@
+import {
+  emojis,
+  aliases,
+  searchAliases,
+  translations,
+  tonableEmojis
+} from "pretty-text/emoji/data";
+import { IMAGE_VERSION } from "pretty-text/emoji/version";
+const extendedEmoji = {};
+export function registerEmoji(code, url) {
+  code = code.toLowerCase();
+  extendedEmoji[code] = url;
+export function extendedEmojiList() {
+  return extendedEmoji;
+const emojiHash = {};
+// add all default emojis
+emojis.forEach(code => (emojiHash[code] = true));
+// and their aliases
+const aliasHash = {};
+Object.keys(aliases).forEach(name => {
+  aliases[name].forEach(alias => (aliasHash[alias] = name));
+export function performEmojiUnescape(string, opts) {
+  if (!string) {
+    return;
+  // this can be further improved by supporting matches of emoticons that don't begin with a colon
+  if (string.indexOf(":") >= 0) {
+    return string.replace(/\B:[^\s:]+(?::t\d)?:?\B/g, m => {
+      const isEmoticon = !!translations[m];
+      const emojiVal = isEmoticon ? translations[m] : m.slice(1, m.length - 1);
+      const hasEndingColon = m.lastIndexOf(":") === m.length - 1;
+      const url = buildEmojiUrl(emojiVal, opts);
+      const classes = isCustomEmoji(emojiVal, opts)
+        ? "emoji emoji-custom"
+        : "emoji";
+      return url && (isEmoticon || hasEndingColon)
+        ? `<img src='${url}' ${
+            opts.skipTitle ? "" : `title='${emojiVal}'`
+          } alt='${emojiVal}' class='${classes}'>`
+        : m;
+  return string;
+export function isCustomEmoji(code, opts) {
+  if (extendedEmoji.hasOwnProperty(code)) return true;
+  if (opts && opts.customEmoji && opts.customEmoji.hasOwnProperty(code))
+    return true;
+  return false;
+export function buildEmojiUrl(code, opts) {
+  let url;
+  code = String(code).toLowerCase();
+  if (extendedEmoji.hasOwnProperty(code)) {
+    url = extendedEmoji[code];
+  if (opts && opts.customEmoji && opts.customEmoji[code]) {
+    url = opts.customEmoji[code];
+  const noToneMatch = code.match(/([^:]+):?/);
+  if (
+    noToneMatch &&
+    !url &&
+    (emojiHash.hasOwnProperty(noToneMatch[1]) ||
+      aliasHash.hasOwnProperty(noToneMatch[1]))
+    url = opts.getURL(
+      `/images/emoji/${opts.emojiSet}/${code.replace(/:t/, "/")}.png`
+  if (url) {
+    url = url + "?v=" + IMAGE_VERSION;
+  return url;
+export function emojiExists(code) {
+  return !!(
+    extendedEmoji.hasOwnProperty(code) ||
+    emojiHash.hasOwnProperty(code) ||
+    aliasHash.hasOwnProperty(code)
+let toSearch;
+export function emojiSearch(term, options) {
+  const maxResults = (options && options["maxResults"]) || -1;
+  if (maxResults === 0) {
+    return [];
+  toSearch =
+    toSearch ||
+    _.union(_.keys(emojiHash), _.keys(extendedEmoji), _.keys(aliasHash)).sort();
+  const results = [];
+  function addResult(t) {
+    const val = aliasHash[t] || t;
+    if (results.indexOf(val) === -1) {
+      results.push(val);
+  // if term matches from beginning
+  for (let i = 0; i < toSearch.length; i++) {
+    const item = toSearch[i];
+    if (item.indexOf(term) === 0) addResult(item);
+  if (searchAliases[term]) {
+    results.push.apply(results, searchAliases[term]);
+    if (item.indexOf(term) > 0) addResult(item);
+  if (maxResults === -1) {
+    return results;
+  } else {
+    return results.slice(0, maxResults);
+export function isSkinTonableEmoji(term) {
+  const match = _.compact(term.split(":"))[0];
+  if (match) {
+    return tonableEmojis.indexOf(match) !== -1;
+  return false;
diff --git a/app/assets/javascripts/pretty-text/emoji.js.es6.erb b/app/assets/javascripts/pretty-text/emoji.js.es6.erb
deleted file mode 100644
index 09ab4ce..0000000
--- a/app/assets/javascripts/pretty-text/emoji.js.es6.erb
+++ /dev/null
@@ -1,127 +0,0 @@
-import { emojis, aliases, searchAliases, translations, tonableEmojis } from 'pretty-text/emoji/data';
-// bump up this number to expire all emojis
-export const IMAGE_VERSION = "<%= Emoji::EMOJI_VERSION %>";
-const extendedEmoji = {};
-export function registerEmoji(code, url) {
-  code = code.toLowerCase();
-  extendedEmoji[code] = url;
-export function extendedEmojiList() {
-  return extendedEmoji;
-const emojiHash = {};
-// add all default emojis
-emojis.forEach(code => emojiHash[code] = true);
-// and their aliases
-const aliasHash = {};
-Object.keys(aliases).forEach(name => {
-  aliases[name].forEach(alias => aliasHash[alias] = name);
-export function performEmojiUnescape(string, opts) {
-  if (!string) { return; }
-  // this can be further improved by supporting matches of emoticons that don't begin with a colon
-  if (string.indexOf(":") >= 0) {
-    return string.replace(/\B:[^\s:]+(?::t\d)?:?\B/g, m => {
-      const isEmoticon = !!translations[m];
-      const emojiVal = isEmoticon ? translations[m] : m.slice(1, m.length - 1);
-      const hasEndingColon = m.lastIndexOf(":") === m.length - 1;
-      const url = buildEmojiUrl(emojiVal, opts);
-      const classes = isCustomEmoji(emojiVal, opts) ? "emoji emoji-custom" : "emoji";
-      return url && (isEmoticon || hasEndingColon) ?
-             `<img src='${url}' ${opts.skipTitle ? '' : `title='${emojiVal}'`} alt='${emojiVal}' class='${classes}'>` : m;
-  return string;
-export function isCustomEmoji(code, opts) {
-  if (extendedEmoji.hasOwnProperty(code)) return true;
-  if (opts && opts.customEmoji && opts.customEmoji.hasOwnProperty(code)) return true;
-  return false;
-export function buildEmojiUrl(code, opts) {
-  let url;
-  code = String(code).toLowerCase();
-  if (extendedEmoji.hasOwnProperty(code)) {
-    url = extendedEmoji[code];
-  if (opts && opts.customEmoji && opts.customEmoji[code]) {
-    url = opts.customEmoji[code];
-  const noToneMatch = code.match(/([^:]+):?/);
-  if (noToneMatch && !url && (emojiHash.hasOwnProperty(noToneMatch[1]) || aliasHash.hasOwnProperty(noToneMatch[1]))) {
-    url = opts.getURL(`/images/emoji/${opts.emojiSet}/${code.replace(/:t/, '/')}.png`);
-  if (url) {
-    url = url + "?v=" + IMAGE_VERSION;
-  return url;
-export function emojiExists(code) {
-  return !!(extendedEmoji.hasOwnProperty(code) || emojiHash.hasOwnProperty(code) || aliasHash.hasOwnProperty(code));
-let toSearch;
-export function emojiSearch(term, options) {
-  const maxResults = (options && options["maxResults"]) || -1;
-  if (maxResults === 0) { return []; }
-  toSearch = toSearch || _.union(_.keys(emojiHash), _.keys(extendedEmoji), _.keys(aliasHash)).sort();
-  const results = [];
-  function addResult(t) {
-    const val = aliasHash[t] || t;
-    if (results.indexOf(val) === -1) {
-      results.push(val);
-  // if term matches from beginning
-  for (let i=0; i<toSearch.length; i++) {
-    const item = toSearch[i];
-    if (item.indexOf(term) === 0) addResult(item);
-  if (searchAliases[term]) {
GitHub sha: 37c613dd
Approved #2
