FIX: Overriding _MF texts didn't work for en_US
FIX: Overriding _MF texts didn’t work for en_US
diff --git a/lib/js_locale_helper.rb b/lib/js_locale_helper.rb
index 40c48aa..52a6c93 100644
--- a/lib/js_locale_helper.rb
+++ b/lib/js_locale_helper.rb
@@ -185,6 +185,8 @@ module JsLocaleHelper
   def self.find_locale(locale_chain, path, type, fallback_to_english:)
+    locale_chain.map!(&:to_s)
     locale_chain.each do |locale|
       plugin_locale = DiscoursePluginRegistry.locales[locale]
       return plugin_locale[type] if plugin_locale&.has_key?(type)
GitHub sha: aecadcb2
We might want some tests for that.
I agree with @ZogStriP here, this could use a test.
DEV: Add spec to find MF locale for en_US
