FIX: Pluralization error for tag error message
diff --git a/config/locales/server.en.yml b/config/locales/server.en.yml
index 4d10b09..51da541 100644
--- a/config/locales/server.en.yml
+++ b/config/locales/server.en.yml
@@ -4201,7 +4201,9 @@ en:
     title: "Tags"
     staff_tag_disallowed: 'The tag "%{tag}" may only be applied by staff.'
     staff_tag_remove_disallowed: 'The tag "%{tag}" may only be removed by staff.'
-    minimum_required_tags: "You must select at least %{count} tags."
+    minimum_required_tags:
+      one: "You must select at least %{count} tag."
+      other: "You must select at least %{count} tags."
     upload_row_too_long: "The CSV file should have one tag per line. Optionally the tag can be followed by a comma, then the tag group name."
     forbidden:
       in_this_category: '"%{tag_name}" cannot be used in this category'
GitHub sha: b3873b95
