FIX: PostgreSQL fallback was broken due to Rails masking exception (#9633)
The PR https://github.com/rails/rails/pull/36612 changes the raised exception if the error message includes the target database name.
Since the error message contains the hostname, this could be triggered when the hostname contains the database name.
diff --git a/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb b/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb
index b8bfb62..7cc4dce 100644
--- a/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb
+++ b/lib/active_record/connection_adapters/postgresql_fallback_adapter.rb
@@ -154,7 +154,7 @@ module ActiveRecord
         begin
           connection = postgresql_connection(config)
           fallback_handler.initialized ||= true
-        rescue PG::ConnectionBad => e
+        rescue ::ActiveRecord::NoDatabaseError, PG::ConnectionBad => e
           fallback_handler.master_down
           fallback_handler.verify_master
GitHub sha: d59d1704
This commit appears in #9633 which was merged by SamSaffron.
