FIX: Prevent deadlock (#7691)
Before the locking here was added, replying to a post and liking a post at roughly the same time could cause a deadlock.
Liking a post grabs an update lock on the post and then on the topic (to update like counts).
We now lock the replied to post before getting the topic lock so that we can update the replied to post later without causing a deadlock.
diff --git a/lib/post_creator.rb b/lib/post_creator.rb
index 70f60c9..9614a51 100644
--- a/lib/post_creator.rb
+++ b/lib/post_creator.rb
@@ -272,8 +272,18 @@ class PostCreator
   def self.set_reply_info(post)
     return unless post.reply_to_post_number.present?
+    # Before the locking here was added, replying to a post and liking a post
+    # at roughly the same time could cause a deadlock.
+    # Liking a post grabs an update lock on the post and then on the topic (to
+    # update like counts).
+    # Here, we lock the replied to post before getting the topic lock so that
+    # we can update the replied to post later without causing a deadlock.
     reply_info = Post.where(topic_id: post.topic_id, post_number: post.reply_to_post_number)
       .select(:user_id, :post_type)
+      .lock
       .first
     if reply_info.present?
GitHub sha: 34074458
